In vba it was very convenient to use “END” the exit a sub at any point. I have a lot of code that I am trying to translate to .net . I was hopeful if I could find a “END” substitute so that I do not have to rewrite a lot of code.
Thank you in advance
Solved by arcticad. Go to Solution.
You could also simply employ code logic which would preclude the processing of additional code if the appropriate test expression(s) are not satisfied.
"How we think determines what we do, and what we do determines what we get."
