.NET
Valued Contributor
3 Kudos
Post 1 of 6
Enable/Disable PopMenuItem
280 Views, 5 Replies
12-24-2012 12:57 AM
ObjectARX Version: 2010
Language: C#
Hi, I am using PopMenuItem (MenuBar item) by loading custom CUIX.
But I can only load it to the menubar.
I would like to enable or disable the menu item according to the system status.
For example, if no drawing document is open, "Save" menuitem in the "File" menu becomes disable (non-clickable).
And as I open or create a document, "Save" menuitem becomes enable (clickable).
I want to use this for my custom menubar menu.
How could I do this?
If you could give me a sample code snippet, it would be appreciated.
Thank you in advance,
Jake
Moderator
277 Kudos
Post 2 of 6
Re: Enable/Disable PopMenuItem
12-24-2012 01:02 AM in reply to: dynamicscope
PopupMenuItem has property Enable, which can help you.
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
3 Kudos
Post 3 of 6
12-25-2012 08:34 PM in reply to: Alexander.Rivilis
It looks like, in ARX 2010, PopMenuItem does not have "Enable" property.
Moderator
277 Kudos
Post 4 of 6
12-25-2012 10:19 PM in reply to: dynamicscope
I did not write about the class Autodesk.AutoCAD.Customization.PopMenuItem, but the class Autodesk.AutoCAD.Interop.PopMenuItem wich can be accessible with Autodesk.AutoCAD.Interop.dll:
Valued Contributor
3 Kudos
Post 5 of 6
12-26-2012 12:00 AM in reply to: Alexander.Rivilis
I see.. I see..
Did not know there was  Autodesk.AutoCAD.Interop.PopMenuItem as well.
I will check that out.
Thank you.
Moderator
277 Kudos
Post 6 of 6
12-26-2012 03:15 AM in reply to: dynamicscope
Disable/enable menu item Save:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Interop;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcX = Autodesk.AutoCAD.Interop;
[assembly: CommandClass(typeof(Rivilis.MenuTest))]
namespace Rivilis
  public class MenuTest
    [CommandMethod("ToggleSave")]
    public void ToggleSave()
      AcX.AcadApplication app = AcAp.Application.AcadApplication as AcX.AcadApplication;
      if (app != null) {
        AcX.AcadMenuGroups groups = app.MenuGroups;
        foreach (AcX.AcadMenuGroup group in groups) {
          // We want work only with menugroup ACAD
          if (group.Name.ToUpper().CompareTo("ACAD") == 0)  {
            AcX.AcadPopupMenus menus = group.Menus;
            if (menus.Count > 0) {
              foreach (AcX.AcadPopupMenu menu in menus) {
                foreach (AcX.AcadPopupMenuItem menuitem in menu) {
                  string label = menuitem.Label;
                  string caption = menuitem.Caption;
                  string tagstring = menuitem.TagString;
                  if (tagstring.ToUpper().CompareTo("ID_SAVE") == 0) {
                    // Toggle status of PopupMenuItem
                    menuitem.Enable = !menuitem.Enable;
