.NET
eLockViolation
22 REPLIES 22
Message 1 of 23
2172 Views, 22 Replies
eLockViolation
Hi all,
I'm running into a problem. I've created a pallet for my program and I'll be needing to insert blocks from that pallet.
Now I've nailed down the inserting of the blocks etc. But only of I do it by issuing a command from the commandline. If I call
that same procedure from my pallet an exception is thrown "eLockViolation".
Now I've boiled it down to this (removed everything except that which was needed):
_
Public Sub test()
Dim destDB As Database = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = destDB.TransactionManager
Dim myT As Transaction = tm.StartTransaction
Try
Dim btr As BlockTableRecord = CType(myT.GetObject(destDB.CurrentSpaceId, OpenMode.ForWrite, True), BlockTableRecord) ' <--- this throws the exception
Catch ex As Exception
MsgBox(ex.Message)
End Try
End Sub
Giving the command "mytest" from the command line gives no errors. Clicking the button that calls the same sub
throws the exception. What am I doing wrong here? I get the feeling the activedocument is not actually active or
something to that extend.
Rinze
22 REPLIES 22
Message 2 of 23
try locking the document before you open the transaction
dim docLock as documentLock = Application.DocumentManager.MdiActiveDocument.LockDocument()
then, when your code is done executing call the dispose method of the documentLock variable
docLock.dispose()
-Mark P.
Message 3 of 23
MarkPendergraft wrote:
> try locking the document before you open the transaction dim docLock as
> documentLock =
> Application.DocumentManager.MdiActiveDocument.LockDocument() then, when
> variable docLock.dispose() -Mark P.
Thanks, that seems to work. But (there's always a but isn't there) I have to click in
my drawing before my jig shows up. Hovering over a line also doesn't highlight it before
I click in the drawing first. That's a bit of a nuisance. Is there a way to put the focus
on the document? I looked for methods like bringToFront, Select, Focus, SetFocus on the
MdiActiveDocument but it doesn't seem to be there.
Rinze
Message 4 of 23
Further investigation shows me that I seem to have a problem with pictureboxes vs buttons.
My pallet shows previews of the blocks to insert. I show these previews in a pictureboxes.
When I click a picturebox the click event of the picture box fires off the insert routine.
The activewindow doesn't seem to get the focus (even though I hide my palletset for a moment).
When the button is clicked, it works as I want and the document gets the focus immediately.
I even set it up so the picturebox click event is handled by the same sub as the buttonclick.
What am I missing? Why does it even matter that it's a picturebox being clicked and not a button.
The eventhandler for the click has only 1 line and that's the insert function I wrote.
Rinze
Message 5 of 23
A button control can contain an image (at least in .NET 3.5 and VS 2008)
i'm totally guessing at this next part here: i suspect that the control acts differently because it's not designed to take focus in the same way buttons and text boxes are. I couldn't find a tabstop or tabindex property. I'm guessing that the control retains focus even while you're in autocad trying to pick your insertion point.
-Mark
Message 6 of 23
arcticad
You can try to set the focus back to Autocad.
Public Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Public Declare Function SetActiveWindow Lib "user32" (ByVal hWnd As Long) As Long
Public Sub SetAcadFocus()
Dim AcadHandle As Long
Dim WindowReturn As Long
AcadHandle = FindWindow(vbNullString, Application.AcadApplication.Caption)
WindowReturn = SetActiveWindow(AcadHandle)
End Sub
(defun botsbuildbots() (botsbuildbots))
Message 7 of 23
You could try
Autodesk.AutoCAD.Internal.Utils.GraphScr()
You will need to add a reference to the acmgdinternal dll.
Message 8 of 23
BillZndl
Not sure what version you're using but Paletteutils.CS helped me on version 2006 Autocad.
You can use PaletteUtils.ActivateEditor(); to put focus to the Autocad screen.
Here's a link to how to use it in VB.net
http://discussion.autodesk.com/forums/thread.jspa?threadID=728268&tstart=25
HTH
Bill
Message 9 of 23
arcticad
http://www.caddzone.com/PaletteUtils.cs
Message 10 of 23
mohnston wrote:
> You could try Autodesk.AutoCAD.Internal.Utils.GraphScr() You will need
I'm not sure what I'm supposed to do with that. I added that command just before the input and it doesn't seem to do anything.
Rinze
Message 11 of 23
> version 2006 Autocad. You can use PaletteUtils.ActivateEditor(); to put
> focus to the Autocad screen. Here's a link to how to use it in VB.net
> HTH Bill
I'm using AutoCAD 2009, VB 2005 and ObjectARX 2009. I looked at PaletteUtils and converted the ActivateEditor function, but it did not help me 😞
Rinze
Message 12 of 23
Thanks you. But alas, it did not solve my problem 😞
Rinze
Message 13 of 23
I'm getting very frustrated here. It shouldn't be this difficut. I've created a compact vb project with just the basics to
show the problem I'm facing. I've attached it to this message.
If you compile it and netload the DLL you can open the pallet with the command "mytest". If you click on the button you are
prompted for a inputpoint which updates immediately if you move your mouse in the drawing. If you click the image that doesn't
happen. You see the prompt on the commandline, but you have to click inside the drawing first before the input starts updating.
This example doesn't really do anything with the input given, but it's just to show the underlying problem I'm facing.
Normally I would just use buttons with pictures on it, but I need these images to process doubleclicks and singleclicks and
that just doesn't work with buttons.
Rinze
Message 14 of 23
arcticad
Same problem in VS 2008.
You know you could always just use a real button and change the flatstlye to flat.
Then add your image.
Problem solved.
Message 15 of 23
In AutoCAD 2009, add a reference to acmgdinternal.dll,
and then do this just *before* you call GetPoint():
Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
In AutoCAD 2010, you don't have to add the reference to
acmgdinternal.dll, as it was merged into acmdg.dll.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"Rinze" wrote in message news:6186550@discussion.autodesk.com...
arcticad wrote:
> http://www.caddzone.com/...
Message 16 of 23
arcticad schreef:
> Same problem in VS 2008. You know you could always just use a real
> button and change the flatstlye to flat. Then add your image. Problem
> solved.
That doesn't solve my problem because I need to distinguish between
single clicks and double clicks. Otherwise I would have used buttons
already 😉
Rinze
Message 17 of 23
I'll test this as soon as I get back in the office on Monday. For now I
have a long weekend 🙂
Rinze
Message 18 of 23
Unfortunately this didn't work either 😞
Rinze
Message 19 of 23
Alright I have it fixed so I'm putting it up for future reference. It seems all I needed to do was disable my pallet while the point was being picked.
i.e. myPallet.enabled = False. It's weird that hiding the palletset where this pallet was put on didn't work, but just disabling the pallet itself does.
Rinze
Message 20 of 23
Give this a try.
Joe ...
_
Public Sub test()
'get the editor object for the current document
Dim ed As Editor = oAcadApp.DocumentManager.MdiActiveDocument.Editor
'get the working database
Dim dwg As Database = ed.Document.Database
'start a transaction
Using ta As Transaction = dwg.TransactionManager.StartTransaction
Try
'get the current drawing space block table record
Dim btr As BlockTableRecord = ta.GetObject(dwg.CurrentSpaceId,
OpenMode.ForWrite, 0, 0)
'otherwise, tell the user about an error
ed.WriteMessage("A problem occurred because " + ex.Message)
End Try
End Using
End Sub
"Rinze" wrote in message news:6185241@discussion.autodesk.com...
Hi all,
I'm running into a problem. I've ...
”Boost
