.NET
eLockViolation of blocktable
2 REPLIES 2
295 Views, 2 Replies
Why would I get an error that says eLockViolation on the line "BlockTable bt = (BlockTable)thisDB.BlockTableId.GetObject(OpenMode.ForWrite);"
private void StampDrawing(string fullDwgPath, string stampString, bool FullSize)
Document ThisDrawing = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(fullDwgPath);
Database thisDB = ThisDrawing.Database;
Autodesk.AutoCAD.ApplicationServices.TransactionManager tm = ThisDrawing.TransactionManager;
using (Transaction trans = tm.StartTransaction())
BlockTableRecord modelsp = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
DBText stampText = new DBText();
stampText.TextString = stampString;
stampText.Height = 12;
stampText.HorizontalMode = TextHorizontalMode.TextRight;
stampText.Rotation = 0;
modelsp.AppendEntity(stampText);
trans.TransactionManager.AddNewlyCreatedDBObject(stampText, true);
trans.Commit();
tm.Dispose();
ThisDrawing.CloseAndSave(fullDwgPath);
thisDB.Dispose();
The file opens fine but I am unable to get the blocktable.
2 REPLIES 2
Hey Mark,
Are you calling this code from the Application context, like from a palette?
If so, then you'll need to lock the document first.
Bobby C. Jones
wrote in message news:5444860@discussion.autodesk.com...
FullSize)
BlockTable bt =
OpenMode.ForWrite);
true);
trans.Commit();
tm.Dispose();
thisDB.Dispose();
I'm calling it from a dialog button event.
I added:
ThisDrawing.LockDocument();
right after I open the Document.
The eLockViolation error went away but when I open the drawing the text is not added.
Maybe I should start another thread for that problem.
”Boost
