.NET
elockviolation error
4 REPLIES 4
460 Views, 4 Replies
Pls help. I have a function under a form class and i am getting an elockviolation error everytime i execute the function. Does anyone know why this occurs?
Private Sub createP1()
Dim myTransMan As DatabaseServices.TransactionManager
Dim myTrans As DatabaseServices.Transaction
Dim myDwg As Document
Dim myBT As BlockTable
Dim myBTR As BlockTableRecord
Dim startPt As Geometry.Point3d
Dim endPt As Geometry.Point3d
Dim myBTE As SymbolTableEnumerator
myDwg = Application.DocumentManager.MdiActiveDocument
myTransMan = myDwg.TransactionManager
myTrans = myTransMan.StartTransaction
myBT = myDwg.Database.BlockTableId.GetObject(OpenMode.ForWrite) <------ here is where the error is (elockviolation)
Dim i As Integer = 0
Dim bfound As Boolean = False
myBTE = myBT.GetEnumerator
While (myBTE.MoveNext = True) And (Not bfound)
myBTR = myBTE.Current.GetObject(OpenMode.ForRead)
If myBTR.Name = "LineBlock" Then bfound = True
End While
If Not bfound Then
startPt = New Geometry.Point3d(0, 0, 0)
endPt = New Geometry.Point3d(2, 3, 0)
Dim line1 As New Line(startPt, endPt)
myBTR = New BlockTableRecord
myBTR.AppendEntity(line1)
myBT.Add(myBTR)
myTrans.AddNewlyCreatedDBObject(myBTR, True)
myTrans.Commit()
myTrans.Dispose()
myTransMan.Dispose()
End Sub
4 REPLIES 4
The reason of this error is most likely caused by
the way you show your FORM: is it a modal form or modeless form? I'd bet it is
latter (or a Palette). You need to lock the document before making changes to
the drawing database.
Something like this (C# code):
using (DocumentLock lock =
myDwg.LockDocument())
    using (Transaction
tran=mDwg.Database.TransactionManager.StartTransaction())
        //Do your
transaction here...
this occurs?
Dim
Dim myTrans As
Dim myBT As
BlockTable
Dim startPt As
Geometry.Point3d
Dim myBTE As
myDwg =
myTransMan =
myTrans =
myBT =
Dim
While
myBTR =
Then bfound = True
End While
If Not bfound Then
startPt =
0)
myBTR = New
BlockTableRecord
myBTR.Name =
"LineBlock"
myBT.Add(myBTR)
True)
End
If
myTrans.Commit()
myTrans.Dispose()
End
Sub
hi. do i need to unlock the document after i lock it? if yes, how do you unlock a document?
Dispose the DocumentLock will unlock the document.
Notice that I use it with "using.....", which guarantees the Documentlock is
disposed.
hi.
document?
Hi. Is this coding correct? This is done in vb.net and I'm not sure if the drawing is unlocked after the command finished executing. Thanks so much.
Dim lock As DocumentLock
lock = myDwg.LockDocument
Using lock
End Using
”Boost
