.NET
eInvalidInput thrown when trying to remove layerfilters
9 REPLIES 9
Message 1 of 10
sszabo
1618 Views, 9 Replies
I am trying to remove all unprotected layer filters from a DWG and getting the following result:
Command: CLEANLF
Deleting layerfilter[0]: 'Test1'...
Autodesk.AutoCAD.Runtime.Exception: eInvalidInput
   at Autodesk.AutoCAD.LayerManager.LayerFilterCollection.Remove(LayerFilter value)
   at wauCmds.WauCmd.cleanLF_Method()
Deleting layerfilter[1]: 'Test2'...
Deleting layerfilter[2]: 'Group Filter1'...
Layerfilter 'All Used Layers' is protected
Layerfilter 'Unreconciled New Layers' is protected
Layerfilter 'Viewport Overrides' is protected
Layerfilter 'Xref' is protected
Here is the code that produced this output.  Any ideas why the Remove throws this exception?
    <CommandMethod("cleanLF")> _
    Public Sub cleanLF_Method()
        Dim ed As Editor = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
        Using docLock As DocumentLock = acDocMgr.MdiActiveDocument.LockDocument
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                For i As Int32 = 0 To db.LayerFilters.Root.NestedFilters.Count - 1
                    Dim deleteMe As LayerFilter = db.LayerFilters.Root.NestedFilters(i)
                    If deleteMe.AllowDelete Then
                        Try
                            ed.WriteMessage(String.Format("Deleting layerfilter[{0}]: '{1}'...", i, deleteMe.Name) + vbCrLf)
                            db.LayerFilters.Root.NestedFilters.Remove(deleteMe)
                        Catch ex As Exception
                            ed.WriteMessage(ex.ToString + vbCrLf)
                        End Try
                    Else
                        ed.WriteMessage(String.Format("Layerfilter '{0}' is protected", deleteMe.Name) + vbCrLf)
                Next
            End Using
        End Using
    End Sub
 ps I am running AutoCAD 2013 SP1.1 PV: G.114.0
9 REPLIES 9
Message 2 of 10
Balaji_Ram
in reply to: sszabo
Note these lines of code in this blog post : http://through-the-interface.typepad.com/through_the_interface/2008/07/adding-and-remo.html
lfc.Remove(lf);
db.LayerFilters = lft;
It is a local copy of the "LayerFilterTree" that is modified by removing a layer filter and then set back to database.
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 10
sszabo
in reply to: Balaji_Ram
I changed the code as such, same result:
                Dim lft As LayerFilterTree = db.LayerFilters
                        Try
                            ed.WriteMessage(String.Format("Deleting layerfilter[{0}]: '{1}'", i, deleteMe.Name) + vbCrLf)
                        End Try
                    Else
                Next
            End Using
        End Using
    End Sub
 I also tried adding tr.Commit() after the for loop, no change, the filters are still there.  There is an autocad dialog box that kicks in automatically when I try to open a drawing with 20000 layer filters and it cleans it up correctly.  I just need the same functionality through the API to prevent drawings from reaching that point to begin with.
Message 4 of 10
Balaji_Ram
in reply to: sszabo
Hi Steve,
Here is a sample code to delete the first deletable layer filter from the Layer filters collection.
    <CommandMethod("Test")> _
    Public Sub TestMethod()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim lft As Autodesk.AutoCAD.LayerManager.LayerFilterTree = db.LayerFilters
        Dim lfc As Autodesk.AutoCAD.LayerManager.LayerFilterCollection = lft.Root.NestedFilters
            Dim lf As Autodesk.AutoCAD.LayerManager.LayerFilter = lfc(i)
            If lf.AllowDelete Then
                Try
                    ed.WriteMessage(String.Format("Deleting layerfilter[{0}]: '{1}'...", i, lf.Name) + vbCrLf)
                    lfc.Remove(lf)
                    Exit For
                End Try
            Else
                ed.WriteMessage(String.Format("Layerfilter '{0}' is protected", lf.Name) + vbCrLf)
        Next
    End Sub
Balaji
Message 5 of 10
sszabo
Ok, thanks Balaji: your code sortof works.
Removing the Exit For still leaves about half of the filters intact but if I nest the for loop in a while loop and do multiple passes it does remove all layerfilters.
What made the difference is the lfc variable.  The original code works by simply assigning and using this variable, the last assignment (db.LayerFilters = lft) was not necessary:
                Dim lfc As LayerFilterCollection = lft.Root.NestedFilters
                For i As Int32 = 0 To lfc.Count - 1
                    Dim deleteMe As LayerFilter = lfc(i)
                        Try
                            lfc.Remove(deleteMe)
                        End Try
                    Else
                Next
            End Using
        End Using
 Thanks again for your help.
Message 6 of 10
sszabo
One last thing to qualify my previous statement: that last assignment (db.LayerFilters = lft) was necessary for the while loop I mentioned above to clean up left overs in multiple passes.  Just to clarify this here is the solution that seems to be able to remove all layerfilters:
        Dim done As Boolean = False
        While Not done
            Dim filtersLeft As Int32 = 0
                Dim lf As LayerFilter = lfc(i)
                    Try
                        lfc.Remove(lf)
                    End Try
                Else
                    ed.WriteMessage(String.Format("Layerfilter '{0}' is protected. AD={1}",
                                                  lf.Name, lf.AutoDelete) + vbCrLf)
            Next
                    filtersLeft += 1
                    ed.WriteMessage(String.Format("LEFT layerfilter[{0}]: '{1}'...", i, lf.Name) + vbCrLf)
            Next
            If filtersLeft = 0 Then
                ed.WriteMessage(String.Format("DONE! filtersleft={0}", filtersLeft) + vbCrLf)
                done = True
        End While
If there is a less messy more elegant solution that doesn not necessitate multiple passes please let me know.
Steve
Message 7 of 10
Balaji_Ram
in reply to: sszabo
Hi Steve,
Can you try this ?
    <CommandMethod("DeleteAllLayerFilters")> _
    Public Sub DeleteAllLayerFilters()
        Dim totalFilters As Integer = lfc.Count
        Dim i As Integer = 0
        While i < totalFilters
            Dim lf As Autodesk.AutoCAD.LayerManager.LayerFilter = lfc.Item(i)
            ed.WriteMessage([String].Format("{0} Checking {1}...", Environment.NewLine, lf.Name))
                lfc.Remove(lf)
                totalFilters = lfc.Count
                i -= 1
                ed.WriteMessage([String].Format("{0} Deleted {1}", Environment.NewLine, lf.Name))
            i += 1
        End While
    End Sub
Balaji
Message 8 of 10
sszabo
Balaji,
This is a very elegant fast algorithm, kudos!
Thanks a bunch,
Steve
Message 9 of 10
geenakv
in reply to: sszabo
Hi Friends..!!!!
I am trying to do 1 project using vb.net and AutoCAD. In the drawing we have multiple layers and should separately store the Layer blocks with the block names in an Excel Application. I stored the Layer names.But all the entities in the drawing will be stored in the Excel file. I need one by one.
Thanks & Regards
Geena..
Message 10 of 10
mzakiralam
in reply to: geenakv
Hi geenakv,
you should create a new message for your Problem. Please create a new thread in this case. Other People will try to help you. you may notice that this thread has already been marked solved so nobody will look into your message. And please try to make clear what do you want actually. I am Little bit confuse what do you really want.
”Boost
