.NET
Active Member
bherber
Message 1 of 3 (212 Views)
einvalidinput saveas
212 Views, 2 Replies
06-26-2013 07:59 AM
Hello: i have been having issue with saving drawings in Mechanical 2013,  when i debug the code below i am getting a einvalidinput on the Database.SaveAs() method. i currently run the same code on mechanical 2012 and it works fine.  please note i need to save the files in Mechanical 2012 format.  If i use DwgVersion.Current it works without erroring out but i need it to save in the Mechanical 2012 format.
using
ACE = Autodesk.AutoCAD.EditorInput;
using
ACAS = Autodesk.AutoCAD.ApplicationServices;
using
ACR = Autodesk.AutoCAD.Runtime;
using
ACDS = Autodesk.AutoCAD.DatabaseServices;
        ACAS.
Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
if (File.Exists(FileLocation))
if (FasMain.InputBox("Drawing File Exists", "This Drawing File Exists, do you want to overwrite?", ref value) == DialogResult.OK)
                        acDoc.Database.SaveAs(FileLocation,
true, ACDS.DwgVersion.AC2To21, null);
                        ed.WriteMessage(
"\nFile is Saved");
else
                        Close();
else
                    ed.WriteMessage(
"\nFile is Saved");
Employee
artc2
Message 2 of 3 (203 Views)
Re: einvalidinput saveas
06-26-2013 09:04 AM in reply to: bherber
AC2To21 is not a valid format to save to in base AutoCAD.  It is a valid enum value, but it is not a format that base AutoCAD will save to.  Mechanical must be using that enum value to indicate something special for its own data because it still has to save to a valid dwg format which for Mechanical 2012, I think should be the same as base AutoCAD 2012 (enum value AC1024).
Hallex
Message 3 of 3 (188 Views)
06-26-2013 02:18 PM in reply to: bherber
You can check allowed versions from list of enums like this:
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
DwgVersion[] dws = db.GetSupportedSaveVersions();
foreach (DwgVersion dw in dws)
ed.WriteMessage("\n{0}",dw);
