.NET
eInvalidContext exception when calling SubDMesh.ConvertToSolid method
3 REPLIES 3
cgcamilo
1407 Views, 3 Replies
I am using the RealDWG2015 sdk. I am using it to export into dwg my own representation.
The code is something like:
using (Database db = new Database(true, true))
using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
// Open the block table.
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
// Find the model space block and open it for write.
ObjectId modelSpace = bt[BlockTableRecord.ModelSpace];
BlockTableRecord table = (BlockTableRecord)tr.GetObject(modelSpace, OpenMode.ForWrite);
Traverse(table, tr, db); // HERE I start creating entities
tr.Commit();
db.SaveAs(path, DwgVersion.Newest);
In the traverse method at some point I create a SubDMesh and add it to the database. Everything works, but if instead of the SubDMesh database I want to create a Solid3D, I am doing:
Solid3d solid = mesh.ConvertToSolid(true, true);
However I always get "eInvalidContext" when calling that method. Is there any reason for this?
Also, What I doing exactly is exporting my solids which are geometries compused of triangles with share vertices, what would be the best entity in this case? solid3D?
Thank you!
Camilo Cifuentes
3 REPLIES 3
LE3
in reply to: cgcamilo
You may need to provide more code detail of what you use in your traverse method, maybe it is a complex mesh and cannot be converted into a solid, wrapped into try-catch blocks. HTH
cgcamilo
in reply to: LE3
Hello LE3 again,
thank you for your interest in this question. The code is simple, is just this:
SubDMesh mesh = new SubDMesh();
Point3dCollection vertarray = new Point3dCollection();
Int32Collection facearray = new Int32Collection();
// adding points
for (int i = 0; i < allMyPoints.Count; i++)
var p = allMyPoints[i];
vertarray.Add(new Point3d(p.X, p.Y, p.Z));
// adding triangles
for (int i = 0; i < allMyTriangles.Count; i++)
int v1 = allMyTriangles[i * 3];
int v2 = allMyTriangles[i * 3 + 1];
int v3 = allMyTriangles[i * 3 + 2];
facearray.Add(3); // because is a triangle
facearray.Add(v1);
facearray.Add(v2);
facearray.Add(v3);
mesh.SetDatabaseDefaults();
mesh.SetSubDMesh(vertarray, facearray, 0);
// following throws eInvalidContext exception
At the end what I want is to create a dwg file that shows solids when opening it. I know that with "Face" class it works, but Face class represent just a a single triangle (or quad) without sharing vertices among other faces. SubDMesh class do what I want but when I open the generated dwg file I do not see it as a solid (but lines).
Thank you!
Camilo Cifuentes
Balaji_Ram
Hello Camilo,
Can you verify if the mesh is not self-intersecting and closed ?
That is the usual cause of this exception.
I would suggest creating the SubDMesh using the same information in AutoCAD and
converting it to a solid using the "CONVTOSOLID" command.
That should provide some hints on what could be wrong with the mesh.
Also try creating a simple box mesh using your code and see if that succeeds in converting it to a solid.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
”Boost
