.NET
Amremad
Message 1 of 3 (272 Views)
Editing Block Attributes Values
272 Views, 2 Replies
04-02-2013 06:05 AM
hi all
in this code
 Private Function MYSelectionSet(Type As MyType, Name As String) As SelectionSet
        Dim acSelFtr As SelectionFilter
        If Type = MyType.Block Then
            acSelFtr = New SelectionFilter({New TypedValue(DxfCode.BlockName, Name)})
        Else
            acSelFtr = New SelectionFilter({New TypedValue(DxfCode.Start, Name)})
        End If
        MYSelectionSet = Ed.GetSelection(acSelFtr).Value
    End Function
    <CommandMethod("tst")> _
    Public Sub testing()
        Dim MySel As SelectionSet = MYSelectionSet(MyType.Block, "AMR.LEVEL")
        Dim Tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
        If MySel IsNot Nothing Then
            For Each BlKID In MySel.GetObjectIds()
                Dim BlkRef As BlockReference = Tr.GetObject(BlKID, OpenMode.ForWrite)
' What can i write here to access for BlkRef Attributes
Next End If Tr.Commit() End Sub
 i need to access BlkRef Attributes (read & write) values
Once you have in instance of a BlockReference class, you can just loop through its AttributeCollecction property. If you examined the BlockReference class in Object Browser, it would have been fairly obvious.
Code would be like:
For Each objId As ObjectId in BlkRef.AttributeCollection
  Dim attRef As Attributereference=Tr.GetObject(objId, OpenMode.ForWrite)
  Select Case attRef.Tag.ToUpper()
      Case "AAA"
          attRef="XXX"
      Case "BBB"
          attRef="YYY"
  End Select
Next
norman.yuan
Message 2 of 3 (262 Views)
Re: Editing Block Attributes Values
04-02-2013 06:46 AM in reply to: Amremad
Code would be like:
      Case "AAA"
          attRef="XXX"
      Case "BBB"
          attRef="YYY"
  End Select
Next
santoshr0114
Message 3 of 3 (233 Views)
04-02-2013 09:28 PM in reply to: Amremad
amremad_world
You can refer the below link to update block atrributes
http://through-the-interface.typepad.com/through_the_interface/2007/07/updating-a-spec.html
Regards
Santosh
