.NET
.NET
New Member
Ronald22
Message 1 of 2 (271 Views)
Edit properties of ToolPallete ( CatalogItem )
271 Views, 1 Replies
08-23-2006 07:48 AM
I’m kinda new to AutoCad programming and hope I ask the question right :smileyhappy: I atleast couldn’t find another post about this.
Is there a way I can access the properties of a CatalogItem in an existing tool palette?
With the code below I managed to loop through the existing items in the loaded tool palettes.
_
Public Sub Test()
'Initiate ToolPaletteManager
Dim tp As ToolPaletteManager = Autodesk.AutoCAD.Windows.ToolPalette.ToolPaletteManager.Manager
'Initiate the CatalogItems from the toolpalette.
Dim catalogItemCol As CatalogItemCollection = tp.Catalogs
Dim iter As Long
'Iterate through all items in the toolpalette catalog
For iter = 0 To catalogItemCol.Count - 1
Dim catalogMain As CatalogItem
catalogMain = catalogItemCol.Item(iter)
'iterate through all tool palette tabs
Dim iter2 As Long
For iter2 = 0 To catalogMain.ChildCount - 1
Dim catalogSub As CatalogItem
catalogSub = catalogMain.GetChild(iter2)
'Iterate through all items in the palette tab
Dim iter3 As Long
For iter3 = 0 To catalogSub.ChildCount - 1
Dim palItem As CatalogItem
palItem = catalogSub.GetChild(iter3)
'todo
'get the properties of the catalogItem (palItem)
'edit items if needed
Next
Next
Next
End Sub
I found the CustomBaseClass which contains the function .GetToolProperties(), but I have no idea how to use it. If anyone could point me out to the right direction I would really appreciate it.
If you have a better way to access the toolpalette items using VB.Net or C# I would really like to know. I’ve checked the sample SimpleToolPalette, but I can’t make anything out of it, besides creating new Tool palette’s
Many thanks in advance !
nikgl
Message 2 of 2 (271 Views)
Re: Edit properties of ToolPallete ( CatalogItem )
06-11-2007 03:55 AM in reply to: Ronald22
It's old but did anyone found a solution?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
