.NET
Valued Contributor
MattH_Work
Message 1 of 5 (861 Views)
Edit Drawing Properties from Windows Explorer
861 Views, 4 Replies
02-11-2011 03:29 AM
How would I go about editing drawing properties (Title, Author & custom props) without usong AutoCAD. I need to replicate within VB.NET the windows explorer RMB > Properties capability.
I have heard mention of DWGProps.dll but cannot find it anywhere
Regards
MattH
User48
Message 2 of 5 (845 Views)
Re: Edit Drawing Properties from Windows Explorer
02-11-2011 06:35 AM in reply to: MattH_Work
Reading the PROPS is one thing, writing them is another thing!  To allow editing would mean rewriting the entire drawing, not an easy thing.  Stick with a side database inside AutoCAD if you have to edit.
Member
p_isaacs
Message 3 of 5 (583 Views)
03-07-2012 07:27 AM in reply to: MattH_Work
I'd also like to know if this is possible as well. I want to be able to add my titleblock info to the custom properties in a drawing and use that to fill in my titleblock with fields. I've already done this with the file name with the insert field command.
We don't (can't) use Sheet Sets at my work ortherwise I'd be doing that instead.
I am pretty certain that you can do it with other files in Windows like Excel & Word documents. Even if there's 3rd party software that would be fine as well.
arcticad
Message 4 of 5 (578 Views)
03-07-2012 08:30 AM in reply to: p_isaacs
http://forums.autodesk.com/t5/NET/read-autocad-file-without-install-autocad-to-end-user-computer/m-p...
(defun botsbuildbots() (botsbuildbots))
Valued Mentor
cadMeUp
Message 5 of 5 (537 Views)
03-10-2012 07:21 AM in reply to: MattH_Work
You might check out these links:
http://social.msdn.microsoft.com/Forums/en-US/csharpgeneral/thread/bb887b05-2018-4978-b115-c8c98e354...
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8422
I haven't tried the solutions but they may work for you...
Seems like there would be a simple net class that would provide for this!
