I'm trying to edit attributes of a block but is giving error.
private void ChangingAttibutes1(ObjectId[] objectIdList) { for (int i = 0; i < objectIdList.Length; i++) { ObjectId objectId = objectIdList[i]; BlockReference blockReference = (BlockReference)objectId.GetObject(OpenMode.ForWrite); BlockTableRecord blockTableRecord = (BlockTableRecord)blockReference.BlockTableRecord.GetObject(OpenMode.ForWrite); Entity Entity = null; foreach (ObjectId item in blockTableRecord) { Entity = transaction.GetObject(item, OpenMode.ForWrite) as Entity; /* if (Entity.GetType() == typeof(AttributeDefinition)) {*/ AttributeDefinition attributeDefinition = Entity as AttributeDefinition; AttributeReference attributeReference = new AttributeReference(); attributeReference.SetAttributeFromBlock(attributeDefinition, blockReference.BlockTransform); if (attributeReference.Tag == "CREV1") { attributeReference.TextString = myList[0]; } else if (attributeReference.Tag == "TREV1") { attributeReference.TextString = myList[1]; } else if (attributeReference.Tag == "DREV1") { attributeReference.TextString = myList[2]; } else if (attributeReference.Tag == "VREV1") { attributeReference.TextString = myList[3]; } else if (attributeReference.Tag == "AREV1") { attributeReference.TextString = myList[4]; } else if (attributeReference.Tag == "DATAREV1") { attributeReference.TextString = myList[5]; } else if (attributeReference.Tag == "SREV1") { attributeReference.TextString = myList[6]; } //} } } }
Solved by Hallex. Go to Solution.
rivate void ChangingAttibutes1(ObjectId[] objectIdList) { for (int i = 0; i < objectIdList.Length; i++) { ObjectId objectId = objectIdList[i]; BlockReference blockReference = (BlockReference)objectId.GetObject(OpenMode.ForWrite); BlockTableRecord blockTableRecord = (BlockTableRecord)blockReference.BlockTableRecord.GetObject(OpenMode.ForWrite); Entity Entity = null; foreach (ObjectId item in blockReference.AttributeCollection) { Entity = transaction.GetObject(item, OpenMode.ForWrite) as Entity; if (Entity.GetType() == typeof(AttributeReference)) { AttributeReference attributeReference = Entity as AttributeReference; if (attributeReference.Tag == "CREV1") { attributeReference.TextString = myList[0]; } else if (attributeReference.Tag == "TREV1") { attributeReference.TextString = myList[1]; } else if (attributeReference.Tag == "DREV1") { attributeReference.TextString = myList[2]; } else if (attributeReference.Tag == "VREV1") { attributeReference.TextString = myList[3]; } else if (attributeReference.Tag == "AREV1") { attributeReference.TextString = myList[4]; } else if (attributeReference.Tag == "DATAREV1") { attributeReference.TextString = myList[5]; } else if (attributeReference.Tag == "SREV1") { attributeReference.TextString = myList[6]; } } } } }
It worked! Thank you!
Think easier yet to use Dictionary or SortedList to update attributes, e.g. :
[CommandMethod("attupd")] public static void AttributeUpdate() { bool success = true; Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; try { // create options object PromptSelectionOptions pso = new PromptSelectionOptions(); // add messages to options object pso.MessageForRemoval = "\n\tSelect a block references only!"; pso.MessageForAdding = "\n\tSelect a block references >> "; // create filter object for attributed block references: SelectionFilter filter = new SelectionFilter(new TypedValue[] { new TypedValue(0, "insert"), new TypedValue(66, 1) }); // do selection PromptSelectionResult psr = ed.GetSelection(pso, filter); //check if selection is succeed if (psr.Status != PromptStatus.OK) return; using (DocumentLock docloc = doc.LockDocument()) { using (Transaction tr = db.TransactionManager.StartTransaction()) { // get an array of ObjectIds ObjectId[] ids = psr.Value.GetObjectIds(); //tags string[] tags = { "TAG1", "TAG2", "TAG3", "TAG4" }; //to your settings (check yourself): // string[] tags = { "CREV1", "TREV1", "DREV1", "VREV1", "AREV1", "DATAREV1", ",", "SREV1" }; //values string[] values = { "FirstValue", "SecondValue", "ThirdValue", "ForthValue" }; //populate a dictionary with data: Dictionary<string, string> dict = FillDictionary(tags, values); //execute update command AttUpdFromDict(tr, ids, dict); // commit transaction, will be disposed automatically because if it's inside the "Using{}" code block tr.Commit(); } } // you might be want to dispaly a message here in case if the program was ended up succesfully // ed.WriteMessage("Done"); } catch (System.Exception ex) { success = false; Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message + "\n" + ex.StackTrace); } finally { //do nothing or display your message here ed.WriteMessage("\nCommand ended up with result of \"{0}\"",success==true? "Success": "Error"); } } public static Dictionary<string, string> FillDictionary(string[] tags, string[] values) { Dictionary<string, string> dict = new Dictionary<string, string>(); if (tags.Length != values.Length) { throw new System.Exception("Arrays have a different number of elements. Error..."); } for (int i = 0; i < tags.Length; i++) { dict.Add(tags[i], values[i]); } return dict; } public static void AttUpdFromDict(Transaction tr, ObjectId[] objectIdList, Dictionary<string, string> dict) { for (int i = 0; i < objectIdList.Length; i++) { ObjectId objectId = objectIdList[i]; BlockReference blockReference = (BlockReference)tr.GetObject(objectId, OpenMode.ForWrite); foreach (ObjectId item in blockReference.AttributeCollection) { Entity ent = tr.GetObject(item, OpenMode.ForWrite, false) as Entity; if (ent.GetType() == typeof(AttributeReference)) { AttributeReference attRef = ent as AttributeReference; if (dict.ContainsKey(attRef.Tag)) attRef.TextString = dict[attRef.Tag]; } } } }
