.NET
Valued Contributor
dahovey
Message 11 of 11 (53 Views)
Re: Edit and continue won't work with vs2005?
07-28-2006 02:39 PM in reply to: dahovey
well. i said it would be a obvious problem. and it was...
i should have tryed creating a new class library project and started from scratch but i thought i could get it to work with what i had...
the problem ended up being that i changed the output directory in the project options...under compile i changed it to a dir on the root of my harddrive that way it would be easy to select when netloading it.
i'm assuming that visual studio was trying to debug with that dll. And regardless i shouldn't need an advantage like that because of the autoloading script. i just need to open the project and debug.
this has been interesting...
Thanks! for all your help.
