.NET
Edit and continue with Visual Studio 2013 in 64 bit environment
5 REPLIES 5
rtejada
2268 Views, 5 Replies
I just installed the just released Visual Studio 2013 Professional x86 in a Windows 7 X64 with AutoCAD 2014 X64 computer hopping to check the Edit and Continue feature as advertised in http://blogs.msdn.com/b/visualstudioalm/archive/2013/06/26/debugging-support-for-64-bit-edit-and-con...
Did not work for me,
Has anybody been able to do it?
5 REPLIES 5
rtejada
in reply to: rtejada
I just checked in the article that the edit and continue feature was explained for a asp.net application, what I am using is a windows form .net one, this may be only applicable for web applications. Any other comments will be appreciated
tleaxavia
Hello!
It is working for me! Just start from a C# project your acad.exe with managed debugging only (no system code debugging activated, no attach to process...)
But with this solution I have the problem, that all ACAD attributes are invisible on the drawing erea. Also other users have seen this problem here in the group....
rtejada
in reply to: tleaxavia
Thanks for your help, I am using vb.net and I could not find managed debugging only option. I am keep getting the "Changes to 64-bit applications are not allowed"
Regards
RT
jdherman
MText and DBText is also invisible when executing code in debug mode.  The same dll loaded after starting AutoCAD Civil 3D 2014 (not debugging) works fine the text shows up.  A grip shows up for the text when using quickselect and text contents show up in properties, but text is not visible in debug mode.
tleaxavia
in reply to: jdherman
The problem with VS2013 and the invisible text desccused here:
http://forums.autodesk.com/t5/NET/Visual-Studio-2013-Preview-and-AutoCAD-Blocks-with-Attributes/td-p...
”Boost
