.NET
.NET
Distinguished Contributor
4 Kudos
Post 1 of 7
eDeviceNotFound Error when validating PlotInfo
361 Views, 6 Replies
01-21-2013 11:34 AM
I am having problems when trying to modify Layouts plot settings.  I am using the same approach to plot the layouts and it works fine.  Also, it works well when modifying the plot settings for the ModelSpace layout.  I don't know what the problem is.  The ConfigurationName is correct, so is the CanonicalMediaName and the Scale.  I am not very clear about this process. Can someone take a look at my code and help me to figure out what is the problem.
Try
                Trans = db.TransactionManager.StartTransaction
                TableRec = CType(Trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                Layout = CType(Trans.GetObject(TableRec.LayoutId, OpenMode.ForWrite), Layout)
                PltSettings = New PlotSettings(Layout.ModelType)
                PltSettings.CopyFrom(Layout)
                PSValidator = PlotSettingsValidator.Current
                PSValidator.SetPlotConfigurationName(PltSettings, PlotInformation.PrinterName, PlotInformation.PaperSize)
                PSValidator.SetUseStandardScale(PltSettings, True)
                PSValidator.SetStdScaleType(PltSettings, PlotInformation.PlotScale)
                PSValidator.SetPlotType(PltSettings, PlotInformation.PlotExtents)
                PSValidator.SetPlotCentered(PltSettings, False)
                PSValidator.RefreshLists(PltSettings)
                PltInfo = New PlotInfo
                PltInfo.Layout = TableRec.LayoutId
                PltInfo.ValidatedSettings = PltSettings
                PltInfoValidator = New PlotInfoValidator
                PltInfoValidator.MediaMatchingPolicy = MatchingPolicy.MatchEnabled
                PltInfoValidator.Validate(PltInfo)
                Layout.CopyFrom(PltSettings)
                Trans.Commit()
                Return True
            Catch ex As Exception
                MessageBox.Show(ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
                Return False
            End Try
 I am getting the error message "eDeviceNotFound" on the line
Hi John,
To include proper error checking it is necessary to check if the plotInfo is validated and if so, access the ValidatedSettings. This is set after the validation is done by the Validate method. So it is not necessary for us to set it.
Here is the change to include such error checking
pi.OverrideSettings = ps;
PlotInfoValidator piv = new PlotInfoValidator();
piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
piv.Validate(pi);
if (pi.IsValidated)
lo.UpgradeOpen();
lo.CopyFrom(pi.ValidatedSettings);
Have you tried the sample code from my previous reply.
It does save the plot settings to the layout.
ADN Support Specialist
100 Kudos
Post 2 of 7
Re: eDeviceNotFound Error when validating PlotInfo
01-24-2013 10:34 AM in reply to: HJohn1
Hi John,
Here is a blog post that explains a way to list all the available media names and to choose one of them.
http://through-the-interface.typepad.com/through_the_interface/2007/10/allowing-select.html
From the sample code in the blog post, you can make use of the “ChooseDeviceAndMedia” as :
<code>
String[] deviceAndMedia = new String[2];
deviceAndMedia = ChooseDeviceAndMedia();
String device = deviceAndMedia[0];
String media = deviceAndMedia[1];
</code>
This will help rule out any issues with incorrect device / media names.
If you still have the issue, can you please share the full code for me to reproduce the error ?
Balaji
Developer Technical Services
Autodesk Developer Network
4 Kudos
Post 3 of 7
01-28-2013 08:51 PM in reply to: Balaji_Ram
Balaji, thank you for your suggestion.  I get the canonicalmedialist to populate a dropdown to allow the user to select the desired media name.  The program works fine when updating the plotsetting of the model space layout.  I only get the error message when I try to update a paper space layout.  Is there any difference between updating the model and paper space layouts?
100 Kudos
Post 4 of 7
01-29-2013 11:01 PM in reply to: HJohn1
Hi John,
Are you passing "false" as the parameter to the "PlotSettings" constructor. For modelspace layout, it is "true" and for paperspace layouts it is "false". The convenient way is to use the "Layout.ModelType" to get this parameter right.
Here is a sample code that set the plot settings for a paperspace layout.
Hope this helps in identifying the issue with your code. If this does not help, can you please share a code snippet for me to reproduce the error ?
[CommandMethod("SetPS")]
public void SetPSMethod()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    Database db = doc.Database;
    Transaction tr = db.TransactionManager.StartTransaction();
    using (tr)
        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead) as BlockTableRecord;
        Layout lo = tr.GetObject(btr.LayoutId, OpenMode.ForRead) as Layout;
        PlotInfo pi = new PlotInfo();
        pi.Layout = btr.LayoutId;
        PlotSettings ps = new PlotSettings(lo.ModelType);
        ps.CopyFrom(lo);
        PlotSettingsValidator psv = PlotSettingsValidator.Current;
        psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
        psv.SetUseStandardScale(ps, true);
        psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
        psv.SetPlotCentered(ps, true);
        psv.SetPlotConfigurationName(ps, "DWG To PDF.pc3", "ANSI_A_(8.50_x_11.00_Inches)");
        piv.Validate(pi);
        lo.UpgradeOpen();
        lo.CopyFrom(ps);
        tr.Commit();
Balaji
4 Kudos
Post 5 of 7
01-30-2013 09:59 PM in reply to: Balaji_Ram
Yes, I am.  if you look at the fourth code line [ PltSettings = New PlotSettings(Layout.ModelType) ] you can see it.  Now, one thing I am not clear about, what is the difference of [ PltInfo.ValidatedSettings = PltSettings ] as in my code or in your example [ pi.OverrideSettings = ps; ] apart from VB and C#? I would like to save the settings back to the Layout, simillar to Applaying the settings in the plot dialog box.  Thanks for your help.
100 Kudos
Post 6 of 7
01-30-2013 10:30 PM in reply to: HJohn1
Hi John,
piv.Validate(pi);
if (pi.IsValidated)
    lo.UpgradeOpen();
Balaji
4 Kudos
Post 7 of 7
02-04-2013 06:47 AM in reply to: Balaji_Ram
Balaji thank you very much for your help.  I made the change you suggested and I am not getting the error message any more.
