.NET
ed.SwitchToPaperSpace throw an eInvalidInput exception
2 REPLIES 2
FRFR1426
568 Views, 2 Replies
When I'm calling ed.SwitchToPaperSpace in my command, I receive a RuntimeException with the code eInvalidInput. If I try with Application.SetSystemVariable("TILEMODE", 0), AutoCAD crash (AccessViolationException). What can cause this behavior?
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
2 REPLIES 2
_gile
in reply to: FRFR1426
Can you tell more about the context.
AFAIK, TILEMODE sysvar (or Database.TileMode) refers to the model tab (switch from or to the model tab to a layout one) and Editor.SwitchToPaperSpace() method is to be used in a paper space tab to switch from an active floating viewport to the paper space viewport.
Gilles Chanteau
GileCAD
GitHub
FRFR1426
in reply to: _gile
Hi Gilles,
You're right about SwitchToPaperSpace. In fact I'm creating some floating viewport and I need to call SetSystemVariable("TILEMODE", 0) before the creation of the viewports. If I call it after, AutoCAD crashes.
Maxence DELANNOY
Manager
http://wiip.fr
”Boost
