.NET
Easy way to ask for file and directory paths?
5 REPLIES 5
namin
402 Views, 5 Replies
Is there an easy way to ask the user for a directory or file, for saving or opening?
Thanks.
5 REPLIES 5
in reply to: namin
With .NET framework (since you ask here), using OpenFile/SaveFileDialog and
FolderBrowserDialog would be very easy.
"namin" wrote in message news:5817613@discussion.autodesk.com...
opening?
Thanks.
jbooth
in reply to: namin
You could also use the Autodesk.AutoCAD.Windows namespace to access the internal open/save dialogs that match the Autocad application's GUI.
The System.Windows.Forms namespace is a lot easier to use though...
mfernandes
in reply to: namin
so to add the control “OpenFileDialog" you drag the control from the tool box to a form "Form1.vb"....correct?
now how do you access the method from a different class "myCommand.vb"
example I have a form1.vb that has the control  “OpenFileDialog" named OpenFD.
I then have myCommands,vb where I want to access OpenFD.
how do I do that?
        Private Sub getfilename()
            openFD.InitialDirectory = "C:\"
            openFD.Title = "Open a Text File"
            openFD.Filter = "Text Files|*.txt"
            openFD.ShowDialog()
        End Sub
fieldguy
in reply to: mfernandes
In mycommands.vb you create an instance of your form - something like this:
Friend Shared myForm As New form1
Now mycommands can reference the contents of form1 through the instance "myForm", as in myForm.textbox (or whatever form tools you need to access).
If you want the form1 tools to run methods in mycommands, the sub routines need to be declared as Public Shared.
form1.vb can have something like this:
Private Sub somebutton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) HandlescmbFiles.Click
mycommands.processformbuttonclick()
EndSub
mycommands should have Public Shared Sub processformbuttonclick()
This is a good example - it refers to palettes and containers but containers behaviour is very similar to forms.
http://forums.autodesk.com/autodesk/attachments/autodesk/152/26712/1/CP205-2_Mike_Tuersley.pdf
mfernandes
in reply to: fieldguy
thanks.
There is some interesting stuff in the paper by
Mike Tuersley AU2007 that I need to go through
thanks again
”Boost
