.NET
.NET
Valued Contributor
namin
Message 1 of 6 (208 Views)
Easy way to ask for file and directory paths?
208 Views, 5 Replies
01-10-2008 01:35 PM
Is there an easy way to ask the user for a directory or file, for saving or opening?
Thanks.
*Norman Yuan
Message 2 of 6 (208 Views)
Re: Easy way to ask for file and directory paths?
01-10-2008 04:21 PM in reply to: namin
With .NET framework (since you ask here), using OpenFile/SaveFileDialog and
FolderBrowserDialog would be very easy.
"namin" wrote in message news:5817613@discussion.autodesk.com...
opening?
Thanks.
Distinguished Contributor
jbooth
Message 3 of 6 (208 Views)
01-11-2008 01:56 PM in reply to: namin
You could also use the Autodesk.AutoCAD.Windows namespace to access the internal open/save dialogs that match the Autocad application's GUI.
The System.Windows.Forms namespace is a lot easier to use though...
mfernandes
Message 4 of 6 (140 Views)
05-09-2012 09:29 AM in reply to: namin
so to add the control “OpenFileDialog" you drag the control from the tool box to a form "Form1.vb"....correct?
now how do you access the method from a different class "myCommand.vb"
example I have a form1.vb that has the control  “OpenFileDialog" named OpenFD.
I then have myCommands,vb where I want to access OpenFD.
how do I do that?
        Private Sub getfilename()
            openFD.InitialDirectory = "C:\"
            openFD.Title = "Open a Text File"
            openFD.Filter = "Text Files|*.txt"
            openFD.ShowDialog()
        End Sub
Valued Mentor
fieldguy
Message 5 of 6 (131 Views)
05-09-2012 10:52 AM in reply to: mfernandes
In mycommands.vb you create an instance of your form - something like this:
Friend Shared myForm As New form1
Now mycommands can reference the contents of form1 through the instance "myForm", as in myForm.textbox (or whatever form tools you need to access).
If you want the form1 tools to run methods in mycommands, the sub routines need to be declared as Public Shared.
form1.vb can have something like this:
Private Sub somebutton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) HandlescmbFiles.Click
mycommands.processformbuttonclick()
EndSub
mycommands should have Public Shared Sub processformbuttonclick()
This is a good example - it refers to palettes and containers but containers behaviour is very similar to forms.
http://forums.autodesk.com/autodesk/attachments/autodesk/152/26712/1/CP205-2_Mike_Tuersley.pdf
mfernandes
Message 6 of 6 (128 Views)
05-09-2012 11:59 AM in reply to: fieldguy
thanks.
There is some interesting stuff in the paper by
Mike Tuersley AU2007 that I need to go through
thanks again
