.NET
Easy Question
18 REPLIES 18
Message 1 of 19
cjuliano
647 Views, 18 Replies
Easy Question
Can vb.net be used with AutoCAD 2004?
18 REPLIES 18
Message 2 of 19
in reply to: cjuliano
No, it can't. AutoCAD 2005 is the first release
supporting .NET via ObjectARX set of managed functions. I'm suggesting using
AutoCAD 2006 to develop .NET apps.
2004?
Message 3 of 19
cjuliano
So basically I can even get AutoCAD to launch and open a drawing? If that is the case then upgrading is coming much sooner than I thought.
Message 4 of 19
Starting ACAD 2004 can be done out of
VB.NET, but you don't need VB.NET to achieve this (any VB will do) 🙂 Managed
set of functions exposed by ObjectARX 2005 and higher let you manipulate ACAD
objects in "ObjectARX way", plus Framework functionality.
Message 5 of 19
cjuliano
At this point in time I am just working with a drawing manager program so all I need to do is open an AutoCAD drawing using VB.Net.
I have been toying around with it a bit and haven't had much success in starting ACAD or opening my drawing. Are there code examples somewhere?
Thanks for the help.
Message 6 of 19
Just search down this NG for examples (plenty of them, in fact).
wrote in message news:4960481@discussion.autodesk.com...
Message 7 of 19
Check out the .NET programming section of our site. All of the articles on
the site are older and deal with using .NET and AutoCAD's COM API. While
some of the details in them are not true for newer versions, the basics of
them all still hold true. Have a look at the Getting Connected article to
see how to use .NET to open AutoCAD.
Bobby C. Jones
http://www.acadx.com
wrote in message news:4960417@discussion.autodesk.com...
Message 8 of 19
cjuliano
Bobby,
A great deal of the links on "your" site don't go anywhere. I did manage to find the Getting Connected article. Since it is in #C how do I compile it for use in VB.Net???
I'll read through the article as well as check out the rest of this NG so hopefully I can find what I am looking for.
Thanks again.
Message 9 of 19
When I have a moment where I'm not working on AU classes, I'm going to take
a look at that.
R. Robert Bell
wrote in message news:4960521@discussion.autodesk.com...
Bobby,
Thanks again.
Message 10 of 19
Quck helper (late binding):
Dim myApp As Object
myApp
= CreateObject("AutoCAD.Application")
myApp.Visible = True
On the other hand, you may check
href="http://discussion.autodesk.com/forum.jspa?forumID=33">http://discussion.autodesk.com/forum.js...
most of the posts refer to what Bobby implied.
Maksim Sestic
Bobby,
A great deal of
in VB.Net???
again.
Message 11 of 19
cjuliano
I'll check out the post in a moment, thanks. I had seen the late binding as you put it and had that in my code and it worked fine. Now the only issue I have is loading the autocad drawing.
I'm using the code:
acadDoc.Open(FoundDrawingRecord, )
and this keeps throwing some type of exception. Can you explain what the heck I'm doing wrong?
Message 12 of 19
cjuliano
As my own follow up to this post I checked the error code that was being generated. The error is #91 and the error description is the following:
"Object reference not set to an instance of an object"
Any help on this one?
Message 13 of 19
Mikko
Did you set a reference to the active document?
Dim acadDoc As AutoCAD.AcadDocument
acadDoc = ACADApp.ActiveDocument
acadDoc.Application.Documents.Open(FoundDrawingRecord)
Message 14 of 19
cjuliano
Mikko - Thanks a bunch. That did it!!!!!!!!!!!!!!!!!!
Message 15 of 19
cjuliano
Another question...sorry guys. The last post from Mikko got me up and running as long as I have a drawing open. Waht would I do if I had AutoCAD open but no drawing open?
Thanks again.
Message 16 of 19
Mikko
By default AutoCAD starts with a drawing open so you should always have some drawing on your screen. If the user shuts the drawing and your looking at an empty application you could just shut down that AutoCAD application and start a new one with the default drawing on the screen, something like this. I don't know if you can start a new drawing in an empty acad app. Never had to try. Somebody else might have a more viable solution.
Public WithEvents ACADApp As AutoCAD.AcadApplication
Sub GetAcadApplication()
Try
ACADApp = GetObject(, "AutoCAD.Application.16")
ACADApp.Visible = True
Catch
MsgBox("Can't find AutoCAD so I'll try starting a new copy.")
Try
ACADApp = CreateObject("AutoCAD.Application.16")
Catch
MsgBox("Big Big Problem" + vbCrLf + "Closing down.", MsgBoxStyle.Critical)
End
End Try
End Try
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Try
Catch
ACADApp.Quit()
End Try
acadDoc.Application.Documents.Open("c:/temp/test.dwg")
End Sub
Message 17 of 19
cjuliano
Thanks Mikko,
What you have provided is a work around I can use for now, but shutting down AutoCAD and restarting seems to be a waste.
Thanks again for all your help.
Message 18 of 19
Mikko
Here is what you are looking for I think.
Try
Catch
ACADApp.Documents.Add()
End Try
End Sub
Message 19 of 19
cjuliano
Thanks Mikko.
I had just figured out pretty much the same solution when my email notification went off. Again thanks for all the help.
Cujo
”Boost
