.NET
Active Contributor
skeletank
Message 1 of 2 (449 Views)
Dynamically load commands at AutoCAD start
449 Views, 1 Replies
08-25-2010 06:33 AM
Right now I have some explicitly defined commands in C# code like such:
[CommandMethod("SomeCommand")]
public static void SomeCommand()
   //Code
There used to be a large number of AutoCAD scripts that frequently change.  Each script was tied to a command using AutoLISP.  Now I have all of the script information stored in a sql database.  Included in the database information for each script is the old command name.  I need a way using C# to register these commands when I NETLOAD my dll.  Is this or a similar method possible?
I already have two possible solutions but they are not preferred.
1.  Create one explicitly defined command which takes the old command as a parameter.  This option is probably not possible because the users are used to the command names and would prefer not to have to type more.
2.  Create a code generator to explicitly define the commands.  The code generator would defeat the purpose of having a database because you would have to recompile whenever a new command is added, one is deleted, etc.
The undocumented AddCommand() method of the
Autodesk.AutoCAD.Internal.Utils class will do it.
Valued Mentor
caddzone
Message 2 of 2 (415 Views)
Re: Dynamically load commands at AutoCAD start
08-26-2010 04:26 AM in reply to: skeletank
AcadXTabs for AutoCAD
Supporting AutoCAD 2000-2011
