.NET
Distinguished Contributor
wesbird
Message 1 of 4 (99 Views)
Dynamically defun function at load-time
99 Views, 3 Replies
09-21-2005 12:20 PM
Hi
I am new to .net. I go over the lab which are pretty good. Thanks.
I have a question, in .Net, command is defined in the way like:
[CommandMethod("CREATE")]
public void Create()
can I generate a command on the fly?
Thank you
Wes
Vault Pro 2014, Windows 7 64 bit, AutoCAD (ACA, Map) 2014
*Albert Szilvasy
Message 2 of 4 (99 Views)
Re: Dynamically defun function at load-time
09-21-2005 10:03 PM in reply to: wesbird
No.
What are you trying to do?
Albert
wrote in message news:4963330@discussion.autodesk.com...
Hi
Thank you
Wes
wesbird
Message 3 of 4 (99 Views)
09-22-2005 05:12 AM in reply to: wesbird
We plan to create a addin in AutoCAD as a client, it will connect to a server (database/application) through internet. We try to keep every business related on server so the command'd better be generated on the fly.
A workaround is use parameter. Can I use parameter in AutoCAD .NET command?
I tested something on the VB6 dll first. Thank to this newsgroup, I found a solution to create command with parameter like this:
Sub MyMacro()
Dim Param1 As String, Param2 As String
Param1 = ThisDrawing.Utility.GetString(False)
Param2 = ThisDrawing.Utility.GetString(False)
MsgBox "Param1:" & Param1 & ". Param2:" & Param2
End Sub
In my menu, I just add code like:
strCmd = "(command ""-VBARUN"" ""MyMacro"" ""a"" ""b"") "
Is this doable in .NET?
Thank you
Wes
*Albert Szilvasy
Message 4 of 4 (99 Views)
09-22-2005 06:02 PM in reply to: wesbird
Yes, the same thing is doable in .NET.
Albert
wrote in message news:4963910@discussion.autodesk.com...
command?
Sub MyMacro()
End Sub
Thank you
Wes
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
