.NET
Dynamic Block and 2010th block Tables
2 REPLIES 2
459 Views, 2 Replies
Hello, I'm on my first steps into .NET and I'm desperatly trying to "play" with dynamic blocks thrue my own library manager.
So, I actually sucessfully insert my blocks and manipulate the standard dynamic parametters such as visibility, dimensions, angles ...
I've got new 2010th blocks based on tables of parameters.
If I change the value of the parameter that is supposed to update the whole block, the only updated thing is the highlighted value of the drop down list of the bloc. Other values are not updated.
Here is a sample of my code ...
SetCustomProp(myBlk, PropName1, PropValue1)
Public Sub SetCustomProp(ByVal BlockID As DatabaseServices.ObjectId, _
ByVal PropName As String, ByVal PropValue As Short)
Dim myTransMan As DatabaseServices.TransactionManager
Dim myTrans As DatabaseServices.Transaction
Dim myDwg As Document
myDwg = Application.DocumentManager.MdiActiveDocument
myTransMan = myDwg.TransactionManager
myTrans = myTransMan.StartTransaction
Dim myBlockRef As DatabaseServices.BlockReference
myBlockRef = BlockID.GetObject(OpenMode.ForWrite)
Dim myDynamicPropsCollection As _
DatabaseServices.DynamicBlockReferencePropertyCollection
Dim myDynamicProp As _
If myBlockRef.IsDynamicBlock Then
myDynamicPropsCollection = myBlockRef.DynamicBlockReferencePropertyCollection
For Each myDynamicProp In myDynamicPropsCollection
Select Case myDynamicProp.PropertyName.ToUpper
Case PropName.ToUpper
If myDynamicProp.UnitsType = DynamicBlockReferencePropertyUnitsType.Angular Then
myDynamicProp.Value = CDbl(PropValue) * Math.PI / 180
Else
myDynamicProp.Value = PropValue
End Select
Next
'Commit the Transaction
myTrans.Commit()
'Dispose of the Transaction Objects
myTrans.Dispose()
myTransMan.Dispose()
End Sub
I can see the table parameter during the loop into the collection, but no way to access its content or change any value ?
Any help will be welcome !
Eric
2 REPLIES 2
Can you post a sample drawing?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message
news:6270582@discussion.autodesk.com...
/ 180
Else
End Select
Next
myTrans.Commit()
myTrans.Dispose()
End Sub
Eric
Hi ! Here is a block that might better help to understand !
”Boost
