.NET
Dymanic block manipulation after changing UCS
3 REPLIES 3
SRSDS
351 Views, 3 Replies
The dynamic position and angle parameters within the inserted blocks appear to be based on the UCS at the time of insertion and relative to the basepoint of the block. These positions don’t change if the UCS is changed or block is rotated.
I can’t work out how to modify the position parameters if the UCS is not the same as that used when the block was inserted.
Can anyone suggest how I access these positions after changing the UCS?
I’ve tried looking at the ECS of the block reference but I’m not sure if that’s what I need to be using.
3 REPLIES 3
Hallex
in reply to: SRSDS
Just a guess, perhaps set myBlock.BlockTransform to
ed,CurrentCoordintaeSystem matrix,
sorry not tested
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
SRSDS
in reply to: Hallex
I worked it out. Thanks as that pointed me in a direcition.
I had to convert the points to the WCS using
mypnt.TransformBy(bref.BlockTransform)
and then revert them back into the modifed block.
The complication was that a rotation parameter was changing the blocks transformation matrix between collecting the positions points and modifying them so I had to convert the positions back using the modified br.BlockTransform matrix.
mypnt.TransformBy(bref.BlockTransform.Inverse)
Hallex
in reply to: SRSDS
Glad you sorted it out
Cheers 🙂
”Boost
