.NET
.NET
SRSDS
Message 1 of 4 (165 Views)
Dymanic block manipulation after changing UCS
165 Views, 3 Replies
05-28-2013 08:17 AM
The dynamic position and angle parameters within the inserted blocks appear to be based on the UCS at the time of insertion and relative to the basepoint of the block. These positions don’t change if the UCS is changed or block is rotated.
I can’t work out how to modify the position parameters if the UCS is not the same as that used when the block was inserted.
Can anyone suggest how I access these positions after changing the UCS?
I’ve tried looking at the ECS of the block reference but I’m not sure if that’s what I need to be using.
Hallex
Message 2 of 4 (163 Views)
Re: Dymanic block manipulation after changing UCS
05-28-2013 08:34 AM in reply to: SRSDS
Just a guess, perhaps set myBlock.BlockTransform to
ed,CurrentCoordintaeSystem matrix,
sorry not tested
SRSDS
Message 3 of 4 (147 Views)
05-28-2013 11:36 AM in reply to: Hallex
I worked it out. Thanks as that pointed me in a direcition.
I had to convert the points to the WCS using
mypnt.TransformBy(bref.BlockTransform)
and then revert them back into the modifed block.
The complication was that a rotation parameter was changing the blocks transformation matrix between collecting the positions points and modifying them so I had to convert the positions back using the modified br.BlockTransform matrix.
mypnt.TransformBy(bref.BlockTransform.Inverse)
Hallex
Message 4 of 4 (132 Views)
05-28-2013 02:27 PM in reply to: SRSDS
Glad you sorted it out
Cheers :smileyhappy:
