.NET
DWG to PDF Using COM Components
3 REPLIES 3
amitnkukanur
553 Views, 3 Replies
Hello Everybody,
After long time i am back in customization of AutoCAD, now for 2013. What i am trying to do is currently trying to export a dwg to pdf using COM Components. If some one suggests me a way to do this will be really thankfull.
Best Regards
Amit
Senior Software Engineer
3 REPLIES 3
There is a lot of sample-code out there for plotting, so you might search for "PLOT" and "VBA" and use one of that samples  with the "Dwg to Pdf.pc3". >>>try<<<
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
amitnkukanur
in reply to: amitnkukanur
Hello Alfred,
Thanks for reply, am looking the same thing using C# wityh COM Components, not using VBA
Best Regards
Amit
I was suggesting to search with the keyword VBA as you would find the most result using the COM/ActiveX methods.
If you have difficulties to translate VB to C# then try >>>that<<<.
- alfred -
Alfred NESWADBA
”Boost
