.NET
DWG Thumbnail
2 REPLIES 2
244 Views, 2 Replies
DWG Thumbnail
Hi, I'm building a new prog. with dwgthumbnail tool. When I show dwg in
tool and if the dwg is save with 2006, the bitmap background is white, but
if I use 2000 dwg the bipmap background is black. I had the same problem
with R14, I know we can change variable but I don't remember which one.
2 REPLIES 2
fxcastil
The BackColor property.
Also make sure you have the latest version 2.0 of DwgThumbnail because the back ground color propery had problems in earlier versions.
Fred Castillo
Were can find the lastest version, I have 1.3 version. On Autodesk web site?
a écrit dans le message de news:
5086281@discussion.autodesk.com...
Fred Castillo
”Boost
