.NET
ugur35
Message 1 of 6 (426 Views)
dwg file in the excel file in c # winform transfer
426 Views, 5 Replies
05-03-2013 03:31 AM
 How can I dwg file in the excel file in c # winform transfer?
Good Times
Hallex
Message 2 of 6 (410 Views)
Re: dwg file in the excel file in c # winform transfer
05-03-2013 05:03 AM in reply to: ugur35
Try language translator please:
http://translate.google.com/
ugur35
Message 3 of 6 (382 Views)
05-03-2013 06:15 AM in reply to: Hallex
Hallex
Message 4 of 6 (363 Views)
05-03-2013 07:36 AM in reply to: ugur35
Ok, that make a sence,
then try this code, but change before Excel file name,
shhet name and range address:
Require references to:
Microsoft Excel 12.0 Object Library
and
Microsoft Office 12.0 Object Library
#region "Imports"
using System;
using System.Collections.Generic;
using System.Text;
using Microsoft.Office.Interop.Excel;
using Excel = Microsoft.Office.Interop.Excel;
using System.Windows.Forms;
#endregion
     public static void ReadExcel()
            // set file name to read:
            string xlFileName = @"c:\Test\dummy.xls";
            Excel.Application xlApp;
            Excel.Workbook xlBook;
            Excel.Sheets xlSheets;
            Excel.Worksheet xlSheet;
            Excel.Range xlRange;
            // get Excel application
            xlApp = new Excel.Application();
            xlApp.Visible = false;
            object miss = Type.Missing;
            StringBuilder sb = new StringBuilder();
            try
                // try open workbook as read-only
                xlApp.Workbooks.Open(xlFileName, false, true, miss, miss, miss, miss, miss, miss, miss, miss, miss, miss, miss, miss);
                xlBook = xlApp.ActiveWorkbook;
                xlBook.Saved = true;
                xlApp.DisplayAlerts = false;
                xlSheets = xlBook.Worksheets;
                // few ways to get an Excel sheet
                // get sheet by name:
                // xlSheet = (Excel.Worksheet)xlSheets.Item["Big Sheet"];
                // get sheet by index:
                xlSheet = (Excel.Worksheet)xlSheets.Item[1];
                // xlSheet = (Excel.Worksheet)xlSheets.get_Item("Big Sheet");
                // xlSheet = (Excel.Worksheet)xlSheets.get_Item(1);
                // few ways to get an Excel range
                // xlRange = (Excel.Range)xlSheet.Range[xlSheet.Cells[1, 1], xlSheet.Cells[5, 6]];
                // the same as:
                xlRange = (Excel.Range)xlSheet.Range["A1:F5"];//	<-- change range address here
                // read the whole range:
                //object[,] varr = (object[,])xlRange.Value2;
                // the same as:
                object[,] varr = (object[,])xlRange.Value;
                // get sizes of arrary:
                int i = varr.GetUpperBound(0);
                int j = varr.GetUpperBound(1);
                // loop thru array
                for (int a = 0; a < i; a++)
                    Excel.Range xlCell;
                    string cell = "";
                    for (int b = 0; b < j; b++)
                        //cell index in Excel is non zero-based and starts from 1
                        xlCell = (Excel.Range)xlRange.Item[a + 1, b + 1];
                        cell = cell + xlCell.Value.ToString() + "\t";
                    // populate stringbuilder
                    sb.AppendLine(cell);
            catch (System.Exception ex)
                MessageBox.Show(ex.Message);
            finally
                // close all workbooks
                xlApp.Workbooks.Close();
                // quit application
                xlApp.Quit();
                MessageBox.Show(sb.ToString());
ugur35
Message 5 of 6 (273 Views)
05-18-2013 01:40 AM in reply to: Hallex
thank you very much
But data in dwg file
ADN Support Specialist
Balaji_Ram
Message 6 of 6 (206 Views)
05-23-2013 04:34 AM in reply to: ugur35
I have replied to your other post on this topic. The code snippet that I have posted is very minimal and you can get more details on using the Excel API from code snippet that Hallex has shared.
http://forums.autodesk.com/t5/NET/I-want-to-read-data-from-a-DWG-excel-file-using-C/m-p/3933417#M351...
Balaji
Developer Technical Services
Autodesk Developer Network
