.NET
Drawing is busy while SaveAndClose acDoc.
1 REPLY 1
628 Views, 1 Reply
I am working on one macro that read drawing names from excel, opens it, do some modification. After that I would need to save and close active drawing. When I use expression acDoc.SaveAndClose(acDoc.Name)
I am getting g an error - drawing is busy. I can save the drawing use save as method without any problems but can save and close it. Do you know what could be an issue? Probably I have to release that drawing or make it active somehow.
Any help is welcome.
Many thanks,
Peter
1 REPLY 1
Hallex
Methink you have to use P/Invoke
[DllImport ("user32.dll")]
static extern IntPtr SetFocus (IntPtr hWnd);
// Then in the code after save as:
SetFocus (Application.DocumentManager.MdiActiveDocument.Window Handle);
Application.DocumentManager.MdiActiveDocument.CloseAndDiscard();
// not tested, just an idea
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
