.NET
.NET
Active Contributor
pva75
Message 1 of 6 (746 Views)
Draw triangle in segment of polyline in segment direction
746 Views, 5 Replies
09-09-2012 12:39 AM
I want to draw triangle in segment of polyline in segment direction.
I have target segment and center point of it:
  Polyline line = ...
  LineSegment3d centerSegment = line.GetLineSegmentAt(centerSegmentIndex);
  Point3d centerPosition = centerSegment.MidPoint;
I can find direction of this segment:
  Vector3d zaDirection = line.GetLineSegmentAt(centerSegmentIndex).Direction;
Next, I create list of points:
  List<Point3d> points = new List<Point3d>();
  points.Add(centerPosition);
  points.Add(centerPosition.Add(new Vector3d(ZASize, +ZASize, 0)));
  points.Add(centerPosition.Add(new Vector3d(ZASize, -ZASize, 0)));
And draw it:
  wd.Geometry.Polygon(new Point3dCollection(points.ToArray()));
Ok, I have triangle but... it's not in segment direction, it's X-direction.
I try to rotate it:
  points.Add(centerPosition.Add(new Vector3d(ZASize, +ZASize, 0)).RotateBy(0, zaDirection, centerPosition));
But it's not the same as I want.
How I can draw triangle by serment direction?
Pavel.
*Expert Elite*
Hallex
Message 2 of 6 (722 Views)
Re: Draw triangle in segment of polyline in segment direction
09-09-2012 11:15 PM in reply to: pva75
Pavel,
Upload a screenshot or image to see
what is your goal
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Active Contributor
pva75
Message 3 of 6 (718 Views)
09-10-2012 12:40 AM in reply to: Hallex
Example
Pavel.
*Expert Elite*
Hallex
Message 4 of 6 (715 Views)
09-10-2012 01:05 AM in reply to: pva75
Well, I just finished to write an example, but it's not you exactly need
Try to rewrite you code using this example:
       public static Point3d PolarPoint(Point3d basepoint, double angle, double distance)
            // credits to Tony Tanzillo
            return new Point3d(
            basepoint.X + (distance * Math.Cos(angle)),
            basepoint.Y + (distance * Math.Sin(angle)),
            basepoint.Z);
        // by gile (Gilles Chanteau)
        // Clockwise method, returns 1 if p1, p2, p3 are clockwise,
        // 0 if they're aligned, -1 if they're counterclockwise
        public static int Clockwise(Point3d p1, Point3d p2, Point3d
        p3, Vector3d normal)
            const double pi = 3.141592653589793;
            Vector3d v1 = p1.GetVectorTo(p2);
            Vector3d v2 = p1.GetVectorTo(p3);
            double angle = v1.GetAngleTo(v2, normal);
            if (angle == 0.0 || angle == pi)
                return 0;
            else
                if (v1.GetAngleTo(v2, normal) < pi)
                    return -1;
                else
                    return 1;
        [CommandMethod("trio")]
        public static void DrawTriangles()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            bool success = false;
            double ZASize = 10.0;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    ObjectId id = ed.GetEntity("\nSelect Polyline: ").ObjectId;
                    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
                    Autodesk.AutoCAD.DatabaseServices.Polyline pline = ent as Autodesk.AutoCAD.DatabaseServices.Polyline;
                    Plane plan = new Plane(Point3d.Origin, pline.Normal);
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Point3d p1 = new Point3d(); Point3d p2 = new Point3d(); Point3d p3 = new Point3d(); int dir = 0;
                    if (pline.NumberOfVertices>2)
                         p1 = pline.GetPoint3dAt(0);
                         p2 = pline.GetPoint3dAt(1);
                         p3 = pline.GetPoint3dAt(2);
                    dir= Clockwise(p1,p2,p3,pline.Normal);
                    for (int i = 0; i < pline.NumberOfVertices; i++)
                        Point3d ep=new Point3d();
                        if ((!pline.Closed) && ((i + 1) < pline.NumberOfVertices))
                            ep = pline.GetPoint3dAt(i + 1);
                        else if (pline.Closed)
                            try
                            catch
                                ep = pline.GetPoint3dAt(0);
                        else
                            break;
                        Point3d sp = pline.GetPoint3dAt(i);
                        Point3d centerPosition = new Point3d((sp.X + ep.X) / 2, (sp.Y + ep.Y) / 2, (sp.Z + ep.Z) / 2);
                        //I can find direction of this segment:
                        double perp;
                        if (dir > 0)
                             perp = (ep - sp).GetPerpendicularVector().AngleOnPlane(plan);
                        else
                             perp = (sp - ep).GetPerpendicularVector().AngleOnPlane(plan);
                        Point3d ap = PolarPoint(centerPosition, perp, ZASize);
                        //Next, I create list of points:
                        points.Add(sp);
                        points.Add(ap);
                        points.Add(ep);
                        Autodesk.AutoCAD.DatabaseServices.Polyline tri = new Autodesk.AutoCAD.DatabaseServices.Polyline();
                        for (int n = 0; n < points.Count; n++)
                            tri.AddVertexAt(n, new Point2d(points[n].X, points[n].Y), 0, 0, 0);
                        // commented overruling code block, I did't test this part of code
                       // wd.Geometry.Polygon(new Point3dCollection(points.ToArray()));
                        btr.AppendEntity(tri); tr.AddNewlyCreatedDBObject(tri, true);
                    success = true;
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.Message + "\n" + ex.StackTrace);
                success = false;
            finally
                if (success==false)
                Application.ShowAlertDialog(new ErrorStatus().ToString());
~'J'~
Active Contributor
pva75
Message 5 of 6 (697 Views)
09-10-2012 10:09 AM in reply to: pva75
Thanks for idea with Plan class. I did it!
It's my code:
Plane plan = newPlane(Point3d.Origin, line.Normal);
double angle = zaDirection.AngleOnPlane(plan);
List<Point3d> points = newList<Point3d>();
points.Add(centerPosition.RotateBy(angle, line.Normal, centerPosition));
points.Add(centerPosition.Add(newVector3d(ZASize, +ZASize, 0)).RotateBy(angle, line.Normal, centerPosition));
points.Add(centerPosition.Add(newVector3d(ZASize, -ZASize, 0)).RotateBy(angle, line.Normal, centerPosition));
Pavel.
*Expert Elite*
Hallex
Message 6 of 6 (681 Views)
09-10-2012 08:54 PM in reply to: pva75
Glad you solved it
Cheers :smileyhappy:
~'J'~
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
