.NET
Valued Contributor
GrzesiekGP
Message 1 of 4 (306 Views)
Draw lines from WinForm.
306 Views, 3 Replies
03-18-2012 02:19 AM
Hello!
I wrote some stand+alone application (WinForm=, where user can specify dimensions.
Now after button click I want to switch form to current AutoCAD file and prompt user to specify point.
From this point I want to start drawing few lines.
And I don't know how to switch to AutoCad and get current drawing space.
Can anyone help me? Any articles about this would be nice for me :smileyhappy:
Hallex
Message 2 of 4 (296 Views)
Re: Draw lines from WinForm.
03-18-2012 06:51 AM in reply to: GrzesiekGP
Take look at this thread
http://forums.autodesk.com/t5/NET/How-to-pass-parameter-in-interface-to-the-programe-of-dll-file/td-...
~'J'~
Valued Contributor
GrzesiekGP
Message 3 of 4 (286 Views)
03-18-2012 11:11 AM in reply to: GrzesiekGP
Thanks, I've made something that works:
object obj = System.Runtime.InteropServices.Marshal.GetActiveObject("AutoCAD.Application");
AcadApplication acad = (AcadApplication)obj as AcadApplication;
acad.WindowState = AcWindowState.acMax;
AcadDocument adoc = (AcadDocument)acad.ActiveDocument as AcadDocument;
AcadUtility acutil = (AcadUtility)adoc.Utility as AcadUtility;
string prompt1 = null;
double[] pnt;
prompt1 = "Enter block insert point: ";
pnt = acutil.GetPoint(Type.Missing, prompt1);
MessageBox.Show(pnt[0].ToString());
 But tell me one more thing please.
I have also written code, which works good from AutoCAD application like:
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
Editor ed = acadApp.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
 using (Transaction trans = db.TransactionManager.StartTransaction())
  Matrix3d ucs = ed.CurrentUserCoordinateSystem;
                Vector3d normal = new Vector3d(0, 0, 1);
                normal = normal.TransformBy(ucs);
                Point3d finalRodStart = new Point3d(newStartX, newStartY, 0).TransformBy(ucs);
                Point3d finalRodEnd = new Point3d(newEndX, newEndY, 0).TransformBy(ucs);
                Line Rod = new Line(finalRodStart, finalRodEnd);
                BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord btr = (BlockTableRecord)trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                // get current layer
                ObjectId currentLayer = db.Clayer;
                // get layer to draw rod
                ObjectId drawingLayer = layers.SetDrawingLayer(trans, db, layersEnum.layer.K_ZBR).Id;
                Rod.LayerId = (drawingLayer == ObjectId.Null) ? db.Clayer : drawingLayer;
                // if set, go back to the previous layer
                if (!Properties.Settings.Default.RememberPreviousLayer)
                    db.Clayer = Rod.LayerId;
                btr.AppendEntity(Rod);
                trans.AddNewlyCreatedDBObject(Rod, true);
                trans.Commit();
 Am I able to use this code from WinForm level?
Is there any way to cast running (or start acad) application within Autodesk.AutoCAD.ApplicationServices.Application class?
Hallex
Message 4 of 4 (266 Views)
03-18-2012 10:28 PM in reply to: GrzesiekGP
THere are few ways how to do it
In example buiild your project as Class Library
Then add Form
Then add singleton to initialize form, i.e.
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using System.Windows.Forms;
[assembly: CommandClass(typeof(MyProject.InitForm))]
namespace MyProject
    public class InitForm : IExtensionApplication
        public void Initialize()
            Form1 myForm = new Form1();
            myForm.Show();
        public void Terminate()
 Then in Debug tab check radio button "Start project"
 hth
~'J'~
