.NET
Distinguished Contributor
JanetDavidson
Message 1 of 5 (339 Views)
Drag and scale a block depends on cursor location
339 Views, 4 Replies
12-23-2011 06:51 AM
I simplify the question. Let's say I want to insert block and  if cursor is in negative coordinates  block should be  2 times bigger,
other wise the same scale. At the same time when I drag the block Jig it should become bigger as well, in negative coordination.
Don't know how to do that. Any light or help would be appreciated. My real problem is how to drag and change the scale at the same time based on cursor location. Right now I am using point monitor to check the location.
Cheers and Merry Christmas
Janet.
Sounds like you need to implement a jig (e.g. DrawJig class).
Board Manager
StephenPreston
Message 2 of 5 (321 Views)
Re: Drag and scale a block depends on cursor location
12-23-2011 06:11 PM in reply to: JanetDavidson
Cheers,
Stephen Preston
Autodesk Developer Network
JanetDavidson
Message 3 of 5 (316 Views)
12-23-2011 09:26 PM in reply to: StephenPreston
Thanks Stephen,
I am going to try that. Happy Holidays.
Janet.
JanetDavidson
Message 4 of 5 (299 Views)
12-25-2011 01:42 PM in reply to: StephenPreston
Stephen , I tried and it worked. Thanks.
I was trying to just drag the block and in the mean time tried to use transfomby scale matrix3d and it was not the proper way.
Happy holidays.
Hallex
Message 5 of 5 (287 Views)
12-26-2011 12:08 AM in reply to: JanetDavidson
Try another way on your machine
Tested on attributed blocks (non-dynamic)
Imports System.Text
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Namespace VBTemplate
    Public Class BlockReactor
        Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
        Private dm As DocumentCollection
        Private doc As Document
        Private db As Database
        Private ed As Editor
        Private counter As Integer
        ''' <summary>
        ''' Initializing the class members
        ''' </summary>
        Public Sub MyInitialize()
            dm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
            doc = dm.MdiActiveDocument
            db = doc.Database
            ed = doc.Editor
            counter = 0
        End Sub
        ''' <summary>
        ''' Method that will start this DLL
        ''' </summary>
        Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
            'Variables initializing
            If doc Is Nothing Then
                MyInitialize()
            End If
            Dim filt As SelectionFilter = New SelectionFilter(New TypedValue() {New TypedValue(0, "insert"), New TypedValue(66, 1)})
            Dim psr As PromptSelectionResult = ed.SelectAll(filt)
            If psr.Status = PromptStatus.OK Then
                If psr.Value.Count > 0 Then
                    ed.WriteMessage(vbLf & "Selected attributed blocks: {0}", psr.Value.Count)
                    For Each item As ObjectId In psr.Value.GetObjectIds()
                        Using tr As Transaction = db.TransactionManager.StartTransaction()
                            Dim obj As DBObject = tr.GetObject(item, OpenMode.ForRead)
                            If TypeOf obj Is BlockReference Then
                                Dim bref As BlockReference = CType(tr.GetObject(item, OpenMode.ForRead), BlockReference)
                                AddHandler bref.Modified, AddressOf obj_Modified
                            End If
                        End Using
                    Next
                End If
            End If
            AddHandler doc.BeginDocumentClose, AddressOf doc_BeginDocumentClose
            ed.WriteMessage(vbLf + "Changed attributes may be stored in Database on close drawing" _
                            + vbLf + "Initialization done")
        End Sub
        ''' <summary>
        ''' Method that will start on closing document
        ''' </summary>
        Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
            Dim res As PromptSelectionResult = ed.SelectAll(filt)
            Dim eids As ObjectId() = res.Value.GetObjectIds()
            For Each eid As ObjectId In eids
                Dim obj As Entity = DirectCast(eid.GetObject(OpenMode.ForRead, False), Entity)
                If eid.ObjectClass = RXClass.GetClass(GetType(BlockReference)) Then
                    Dim bref As BlockReference = DirectCast(TryCast(obj, BlockReference), BlockReference)
                    RemoveHandler obj.Modified, AddressOf obj_Modified 'unregister event
                End If
            Next
            RemoveHandler doc.BeginDocumentClose, AddressOf doc_BeginDocumentClose 'unregister event
        End Sub
        Friend Sub obj_Modified(ByVal sender As Object, ByVal e As EventArgs)
            Dim bref As BlockReference = Nothing
            bref = DirectCast(sender, BlockReference)
            Dim p As Point3d = bref.Position
            Dim hdl As String = bref.Handle.ToString
            doc.SendStringToExecute("_SCALE " & "(handent " & Chr(34) & hdl & Chr(34) & ")" & vbCr & Chr(32) & p.X.ToString + "," & p.Y.ToString & Chr(32) & "2.0" & vbCr, False, False, False)
            RemoveHandler bref.Modified, AddressOf obj_Modified
            counter += 1
        End Sub
        Private Sub doc_BeginDocumentClose(ByVal sender As Object, ByVal e As DocumentBeginCloseEventArgs)
            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Modified : " & counter.ToString & " blocks")
        End Sub
End Class
End NameSpace
