.NET
Active Contributor
dancalgary
Message 1 of 2 (224 Views)
Double Click capture
224 Views, 1 Replies
08-22-2013 03:40 PM
Hi
I am trying to build a code without using CUI editing
when I doubleclick a  block called Block_text to display a custom form
but also I do not want to take out the double click behaviour from autocad when I click on another objects
Can you point me to the right path?
I do not want to run "mst" command when I want to display the form
So far I gathered  the following code:
' System
Imports System
Imports System.Collections.Generic
Imports System.Linq
Imports System.Text
Imports System.Linq.Expressions
' AutoCAD
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports acApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.EditorInput
' AutoCAD Interop
Imports acOp = Autodesk.AutoCAD.Interop
Imports acOpCom = Autodesk.AutoCAD.Interop.Common
Namespace Test1
    PublicClassCommands
        Public db AsDatabase = HostApplicationServices.WorkingDatabase
        Public ActiveDoc_vb_net AsDocument = acApp.DocumentManager.MdiActiveDocument
        Public ed AsEditor = ActiveDoc_vb_net.Editor
        Private acDoc As acOp.AcadDocument
        Private handlerAdded AsBoolean = False
        Private Forma1 AsNewdouble_click_form' I created a form, and I added a Textbox1 to it
        PublicFunction ThisDrawing()
            ReturnacApp.DocumentManager.MdiActiveDocument.AcadDocument
        EndFunction
        PublicSub eventDoubleClick()
            Try
                If handlerAdded = FalseThen
                    acApp.SetSystemVariable("DBLCLKEDIT", 0)
                    acDoc = CType(ThisDrawing(), Autodesk.AutoCAD.Interop.AcadDocument)
                    AddHandler acDoc.BeginDoubleClick, AddressOf callback_DoubleClick
                    handlerAdded = True
                Else
                EndIf
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                MsgBox(ex.Message, MsgBoxStyle.Critical)
            Finally
                acApp.SetSystemVariable("DBLCLKEDIT", 1)
            EndTry
        EndSub
        PrivateSub callback_DoubleClick(ByVal pickPoint AsObject)
            Dim PromptSelectionResult1 AsPromptSelectionResult = ActiveDoc_vb_net.Editor.GetSelection()
            Dim msg AsString = ""
            Using docLock AsDocumentLock = ActiveDoc_vb_net.LockDocument()
                If PromptSelectionResult1.Status <> PromptStatus.OK Then
                EndIf
                If PromptSelectionResult1.Value.Count <> 1 Then
                EndIf
                Dim id As Autodesk.AutoCAD.DatabaseServices.ObjectId = PromptSelectionResult1.Value(0).ObjectId
                Try
                    Using acTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = _
                        ActiveDoc_vb_net.TransactionManager.StartTransaction()
                        Dim dbObj As Autodesk.AutoCAD.DatabaseServices.DBObject = _
                        acTrans.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
                        Dim ent As Autodesk.AutoCAD.DatabaseServices.Entity = _
                            TryCast(dbObj, Autodesk.AutoCAD.DatabaseServices.Entity)
                        Forma1.Text = ent.GetType().ToString()
                        If ent IsNothingThen
                            Exit Sub
                        Else
                            Dim blockRef As Autodesk.AutoCAD.DatabaseServices.BlockReference = _
                                TryCast(ent, Autodesk.AutoCAD.DatabaseServices.BlockReference)
                            If blockRef IsNothingThen
                                RemoveHandler acDoc.BeginDoubleClick, AddressOf callback_DoubleClick
                                Exit Sub
                            Else
                                ActiveDoc_vb_net.Editor.WriteMessage(blockRef.BlockName)
                                acApp.ShowModalDialog(Forma1)
                            EndIf
                        EndIf
                        acTrans.Commit()
                    EndUsing
                    Dim msgStr AsString = String.Format("EX: '{0}'", ex.ToString)
                Catch
                    Dim msgStr AsString = String.Format("ERR: '{0}", Err.Description)
                EndTry
            EndUsing
        EndSub
        <CommandMethod("mst")> _
        PublicSub massStraight()
            Try
                ' Call this to override the default block dblclk event handler
                eventDoubleClick()
            EndTry
        EndSub
    EndClass
EndNamespace
norman.yuan
Message 2 of 2 (199 Views)
Re: Double Click capture
08-23-2013 06:38 AM in reply to: dancalgary
If you are not using Acad2009 or earlier, you do not have to use AcadDocument.BeginDoubleClick event from COM API, you can use Application.BeginDoubleClick in ,NET API, in conjunction with other more controls mechnism provided by .NET API.
There was a lengthy discussion in this forum and that inspired me wrinte 2 articles on this topic:
http://drive-cad-with-code.blogspot.ca/2012/12/custom-double-click-action-using.html
http://drive-cad-with-code.blogspot.ca/2013/03/update-custom-double-click-action-using.html
It might be a bit helpful.
