Just thought I'd post this..
Arcticad gave me code to work out the right keywords to search for. The only google hit was a chinese website.
I added it to his/her code but didn't delete any of the existing handlers just in case.
Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.ApplicationServices Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application Imports Autodesk.AutoCAD.EditorInput <Assembly: ExtensionApplication(GetType(VbExtApp))> Public Class VbExtApp Implements Autodesk.AutoCAD.Runtime.IExtensionApplication Private DocMan As DocumentCollection 'Initialize sub Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize DocMan = AcApp.DocumentManager AddHandler DocMan.DocumentCreated, AddressOf callback_documentCreated AddHandler DocMan.DocumentActivated, AddressOf callback_documentActivated Dim doc As Document For Each doc In DocMan Dim db As Database = doc.Database AddHandler db.ObjectModified, AddressOf callback_ObjectModified AddHandler db.ObjectAppended, AddressOf callback_ObjectAppended AddHandler db.ObjectErased, AddressOf callback_ObjectErased AddHandler Application.BeginDoubleClick, AddressOf callback_BeginDoubleClick Next End Sub 'BeginDoubleClick Public Sub callback_BeginDoubleClick(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.BeginDoubleClickEventArgs) MsgBox("Double Click") Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim ed As Editor = doc.Editor Dim res As PromptSelectionResult = ed.SelectImplied() Dim ss As SelectionSet = res.Value If ss IsNot Nothing Then If ss.Count = 1 Then Using tr As Transaction = doc.TransactionManager.StartTransaction() Dim br As BlockReference = DirectCast(tr.GetObject(ss(0).ObjectId, OpenMode.ForRead), BlockReference) If br IsNot Nothing Then DoubleClickBlock(br.ObjectId) End If End Using End If End If End Sub 'Terminate sub Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate RemoveHandler DocMan.DocumentCreated, AddressOf callback_documentCreated End Sub Public Shared Sub callback_ObjectModified(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs) 'MsgBox("Something was modified") ID = e.DBObject.ObjectId ObjectModified(ID) End Sub Public Shared Sub callback_ObjectAppended(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs) 'MsgBox("Something was Appended") End Sub Public Shared Sub callback_ObjectErased(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectErasedEventArgs) 'MsgBox("Something was Erased") ID = e.DBObject.ObjectId ObjectErased(ID) End Sub Private Sub callback_documentCreated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs) If e.Document = Nothing Then Exit Sub Else ' MsgBox("Document Created") End If End Sub Private Sub callback_documentActivated(ByVal sender As Object, ByVal e As DocumentCollectionEventArgs) If e.Document = Nothing Then Exit Sub Else ' MsgBox("Document Active") End If End Sub End Class
Just at the quick glance...
- - you have to add reference:
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
and also there is no Autodesk.AutoCAD.ApplicationServices.BeginDoubleClickEventArgs
this event is of AcadApplication, anyway I didn't see it in Intellisence drop-down
-- after adding references I showed above use simple BeginDoubleClickEventArgs instead
-- ID is not declared , the same with any subs:
ObjectErased(ID) &etc
Hi Hallex,
I am a newb so bear with me.
Took a while to find this but it does seem to kick off the event and return an ID without the need for interop references
Interop connects with 'old style' compentry? I don't know what interop means 😞
You have to add reference (References --> COM tab)
-- AutoCAD 2XXX Type Library
-- AutoCAD/ObjectDBX Common 1X.X Type Library
Thanks for info, Jeff,
I'm in A2009 yet
Can you provide the same way for 2010
(for one of friends of mine 🙂
Oleg
Thanks Hallex,
I probably should use your suggestion from the sounds of things. Some computers in our office do have pre 2010 installations.
