.NET
richard.harris
577 Views, 6 Replies
donut
i'm trying to draw a simle donut could someone give me sme insight please.
6 REPLIES 6
fixo
in reply to: richard.harris
Try this one
Imports System
Imports System.Collections
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports AcadRT = Autodesk.AutoCAD.Runtime
Imports AcadED = Autodesk.AutoCAD.EditorInput
Imports AcDB = Autodesk.AutoCAD.DatabaseServices
Imports AcadApp = Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.Windows
Shared Function getreal(ByVal msg As String, ByRef d As Double) As Boolean
Dim ed As Editor = AcadApp.DocumentManager.MdiActiveDocument.Editor
Dim res As PromptDoubleResult = ed.GetDouble(msg)
If res.Status PromptStatus.OK Then
Return False
d = res.Value
Return True
End Function
Shared Function getpoint(ByVal msg As String, ByRef P As Point3d) As Boolean
Dim res As PromptPointResult = ed.GetPoint(msg)
Return False
P = res.Value
Return True
End Function
Public Shared Sub CreateDonut()
Dim db As AcDB.Database = HostApplicationServices.WorkingDatabase
Dim ptArr As Point3dCollection = New Point3dCollection
Dim eRad As Double
Dim iRad As Double
Dim p As Point3d = New Point3d
Try
Using tr As AcDB.Transaction = db.TransactionManager.StartTransaction()
Using bt As BlockTable = CType(tr.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
Using btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
If Not getreal(ControlChars.CrLf & "Enter outer radius: ", eRad) Then
Return
If Not getreal(ControlChars.CrLf & "Enter inner radius: ", iRad) Then
Return
If Not getpoint(ControlChars.CrLf & "Pick point: ", p) Then
Return
Dim spt As Point2d = New Point2d(p.X - eRad + (eRad - iRad) / 2, p.Y)
Dim ept As Point2d = New Point2d(p.X + eRad - (eRad - iRad) / 2, p.Y)
ptArr.Add(New Point3d(spt.X, spt.Y, p.Z))
ptArr.Add(New Point3d(ept.X, ept.Y, p.Z))
Dim blgArr As DoubleCollection = New DoubleCollection()
blgArr.Add(1.0)
blgArr.Add(1.0)
Dim oPline As Polyline2d = New Polyline2d(Poly2dType.SimplePoly, ptArr, 0.0, True, eRad - iRad, eRad - iRad, blgArr)
oPline.Closed = True
btr.AppendEntity(oPline)
tr.AddNewlyCreatedDBObject(oPline, True)
tr.Commit()
End Using
End Using
End Using
Catch ex As Exception
MsgBox(ex.Message & ControlChars.CrLf & ex.StackTrace, MsgBoxStyle.Critical, "Exception")
End Try
End Sub
~'J'~
GetDistance() is for getting distances, not GetDouble().
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:5987675@discussion.autodesk.com...
Try this one
fixo
Thanks again, I've forgot about
~'J'~
fixo
As Tony said:
Shared Function getdistance(ByVal msg As String, ByRef d As Double) As Boolean
Dim res As PromptDoubleResult = ed.GetDistance(msg)
If res.Status <> PromptStatus.OK Then
Return False
d = res.Value
Return True
End Function
Return False
P = res.Value
Return True
End Function
Dim eRad As Double
Dim iRad As Double
Try
If Not getdistance(ControlChars.CrLf & "Enter outer radius: ", eRad) Then
Return
If Not getdistance(ControlChars.CrLf & "Enter inner radius: ", iRad) Then
Return
Return
blgArr.Add(1.0)
blgArr.Add(1.0)
tr.Commit()
End Using
End Using
End Using
End Try
End Sub
~'J'~
thank you both so much this is a great help.... 🙂
wrote in message news:5987719@discussion.autodesk.com...
Boolean
Dim ed As Editor =
Return False
d = res.Value
Return True
End Function
Boolean
Dim ed As Editor =
Return False
P = res.Value
Return True
End Function
Dim ed As Editor =
Dim eRad As Double
Dim iRad As Double
Try
Return
Return
", p) Then
Return
DoubleCollection()
blgArr.Add(1.0)
blgArr.Add(1.0)
iRad, blgArr)
tr.Commit()
End Using
End Using
End Using
End Try
End Sub
~'J'~
i'm using C# i'll try to use your example and translate to C#
wrote in message news:5989864@discussion.autodesk.com...
Boolean
Dim ed As Editor =
Return False
d = res.Value
Return True
End Function
Boolean
Dim ed As Editor =
Return False
P = res.Value
Return True
End Function
Dim ed As Editor =
Dim eRad As Double
Dim iRad As Double
Try
Return
Return
", p) Then
Return
DoubleCollection()
blgArr.Add(1.0)
blgArr.Add(1.0)
iRad, blgArr)
tr.Commit()
End Using
End Using
End Using
End Try
End Sub
~'J'~
”Boost
