.NET
.NET
Valued Contributor
2 Kudos
Post 1 of 11
does working SelectWindowPolygon just with 4 points ?
380 Views, 10 Replies
10-20-2010 02:50 PM
inside this area i have a circle..
lpt.Add(new Point3d(5.0, 5.0, 0.0));
               lpt.Add(new Point3d(13.0, 15.0, 0.0));
               lpt.Add(new Point3d(12.0, 9.0, 0.0));
               lpt.Add(new Point3d(5.0, 12.0, 0.0));
// if I add the red row  SelectWindowPolygon return Error. without this its return the objects.
               PromptSelectionOptions Opts = new PromptSelectionOptions();
               Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
               Point3dCollection Polygon = new Point3dCollection(lpt.ToArray());
               PromptSelectionResult res   = ed.SelectWindowPolygon(Polygon);
maybe I'm a stupid...but I guess that a polygon could be have more then 4 vertex..
217 Kudos
Post 2 of 11
Re: does working SelectWindowPolygon just with 4 points ?
10-20-2010 03:06 PM in reply to: bikelink
SelectWindowPolygon()'s argument Point3dCollection can contains 3 or more Point3ds (To make a polygon, you need at least 3 points, right?).
Here "Window" does not mean a rectangle with 4 corners (while in SelectWindow(), "Window" means a rectangle, but only 2 points representing 2 opposite corners required). It means "window" selection, as opposed to "crossing" selection. That is only entities completely contained inside the polygon will be selected.
Valued Contributor
2 Kudos
Post 3 of 11
10-20-2010 03:12 PM in reply to: bikelink
if I try to use with lisp (ssget "_wp".... (pointlist))
I can use 4 ,5 ,n points.  isn't it ?
of course i want to retrieve the object inside my polygon (6 vertex) fully included! (window)
Valued Mentor
13 Kudos
Post 4 of 11
10-20-2010 03:33 PM in reply to: bikelink
Does that polygon cross itself or have to closed regions
You can also find your answers @ TheSwamp
Valued Mentor
13 Kudos
Post 5 of 11
10-20-2010 03:36 PM in reply to: Jeffrey_H
Never mind that was answered here
http://www.theswamp.org/index.php?topic=35384.0
Valued Contributor
2 Kudos
Post 6 of 11
10-20-2010 03:37 PM in reply to: Jeffrey_H
it's very simple... I have 4 points (not a simple square) (sometime 5 points) and I want to check all entities fully  inside.
The dbobjects could be any kind (solid3d, circles, ecc...)
54 Kudos
Post 7 of 11
10-20-2010 04:21 PM in reply to: bikelink
Jeffrey_H (and Jeff_M at the swamp) are correct.  The points you provided will generate a boundary that crosses itself, which is not allowed.  (oops.  my eyes are playing tricks and I skipped right over the first point in your list, which made what I wrote before in these parenthesis invalid)
I don't know how you are coming up with the points you need to define your polygon, but in your example, if you swap the second and third points, it will work.
Coincidently, there is a recent thread on this discussion group about how to programmatically determine if a polyline intersects itself.   I just tried to find it, but I am having some trouble locating it at the moment
Valued Contributor
2 Kudos
Post 8 of 11
10-20-2010 04:37 PM in reply to: chiefbraincloud
ok , sorry but with this points i haven't intersections
that's a real situation.
              lpt.Add(new Point3d(2526.11913296339, 4761.82097707599, 0));
               lpt.Add(new Point3d(2250.71913296339, 4761.82097707599, 0));
               lpt.Add(new Point3d(2299.01913296339, 4713.52097707599, 0));
               lpt.Add(new Point3d(2526.11913296339, 4713.52097707599, 0));
the shape (black color)  is regular, without intersections (i moved out from others lines in order to show it)
under this points we have some entities but the selection fails!
Valued Contributor
2 Kudos
Post 9 of 11
10-20-2010 04:45 PM in reply to: bikelink
ok discovered....i must to make a little offset ..else  nothing is really fully inside !
54 Kudos
Post 10 of 11
10-20-2010 04:51 PM in reply to: bikelink
After Looking at your image, I was going to suggest that circle might be touching the boundary.
And FYI,  I was going to say that there is no need to provide the final closing coordinate, as AutoCAD will automatically treat the polygon as closed.
