.NET
Does any one know how to bind xref's
8 REPLIES 8
Message 1 of 9
michael_vanhoose
636 Views, 8 Replies
Does any one know how to Bind Xrefs in the drawings using .net? There must be a easy way other than inserting it in a as a block then saving the state of all those layers.
8 REPLIES 8
Message 2 of 9
cadMeUp
in reply to: michael_vanhoose
I have not tried it but this should work:
Database.BindXrefs(Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection, bool)
Call this on a database that contains the Xref that you want to bind in.
You can find it in the object browser.
Message 3 of 9
//Database.BindXrefs(Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection,
bool)
What AutoCAD version?
As far for A2007.... you can P/Invoke acedXrefBind();
There are some samples already done and posted here.... do a search in this
newsgroup.
Message 4 of 9
I have 2007 and I can't see db.bindxref in my object browser. I did a search many times on xrefs,bind and nothing comes up. if you have a link of something that would be very nice.
Also, thanks for your reply.
Message 5 of 9
Strange....
but here is something:
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet
= CharSet.Unicode,
EntryPoint =
"acedXrefBind@@YAAW4ErrorStatus@Acad@@PB_W_N1PAVAcDbDatabase@@@Z")]
extern public static ErrorStatus acedXrefBind(string XrefBlockname, bool
bInsertBind, bool bQuiet, IntPtr db);
using (Transaction tr =
db.TransactionManager.StartTransaction())
BlockReference blkRef = tr.GetObject(id,
OpenMode.ForWrite, false) as BlockReference;
BlockTableRecord blkRec =
(BlockTableRecord)tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForWrite);
if (blkRec.IsFromExternalReference)
string blockname = blkRec.Name, fileName =
blkRec.PathName; Point3d origin = blkRec.Origin;
if (acedXrefBind(blockname, true, true,
HostApplicationServices.WorkingDatabase.UnmanagedObject) == ErrorStatus.OK)
ed.WriteMessage("\nXref was binded...");
Message 6 of 9
cadMeUp
Sorry, I did not realize it was for 2007 and you are right I do not see it there for that version.
You could try this:
string xrefname = "SOME_XREF_NAME";
string comStr = String.Format("-xref bind {0}\n", xrefname);
AcadApp.DocumentManager.MdiActiveDocument.SendStringToExecute(comStr, false, false, false);
It will produce what you want, but it is an odd way.
Message 7 of 9
did they add this in 2008 Database.BindXrefs(Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection,
bool)? I guess I'm better off using COM. I'm trying to get away from COM.
Message 8 of 9
cadMeUp
Yes, it is in 2008. Strange that they don't have a direct way in 2007. You could insert the xref database into the dwg that contains it, as a block, and just give it a new block name, but that would not remove the xref from the database which is what I assume you want? Can I ask what the reason is for binding the xref to the dwg?
Message 9 of 9
When we send them to customers we bind them. That's good to know about 2008 though. They must have thought about.
”Boost
