.NET
.NET
Valued Contributor
Ertqwa
Message 1 of 7 (768 Views)
DocumentManager.Open("drawing.dwg", false) - READONLY or not
768 Views, 6 Replies
07-29-2012 08:47 AM
Hello Forum,
if I open a drawing with DocumentManager.Open("drawing.dwg", false) and it is already open (or the user has no rights to write to it), the drawing is opened in READONLY mode without warning.
Is there way to check if DocumentManager.Open("drawing.dwg", false) will open the drawing normal or READONLY?
Thank you.
Hallex
Message 2 of 7 (762 Views)
Re: DocumentManager.Open("drawing.dwg", false) - READONLY or not
07-29-2012 10:40 AM in reply to: Ertqwa
See if this helps
		<CommandMethod("rdo", CommandFlags.Session)> _
		Public Sub testReadOnly()
			Dim filename As String = "C:\Test\WorkingDrawing.dwg"
			Dim dm As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
			Dim curdoc As Document = dm.MdiActiveDocument
			Using doclock As DocumentLock = curdoc.LockDocument()
				Dim doc As Document = dm.Open(filename, True)
				Dim ed As Editor = doc.Editor
				dm.MdiActiveDocument = doc
				ed.WriteMessage(vbLf & "Is Read-Only? {0}", doc.IsReadOnly.ToString())
				Dim foo As String = ed.GetString(vbLf & "Type any key: ").StringResult
				dm.MdiActiveDocument = curdoc
				doc.CloseAndDiscard()
			End Using
		End Sub
~'J'~
Valued Contributor
Ertqwa
Message 3 of 7 (724 Views)
07-31-2012 10:31 AM in reply to: Hallex
Thank you for the response.
Doesn't your code open the drawing readonly and then tell me that the drawing is opened in readonly mode? I want to know if DocumentManager.Open("drawing.dwg", false) will open the drawing readonly or not, before I execute it. That way I can inform the user that the drawing can only be opened in readonly mode, and ask the user if he/she wants that.
Hallex
Message 4 of 7 (714 Views)
07-31-2012 01:52 PM in reply to: Ertqwa
Your problem is on you couldn't read this property,
so you can try this code, I saved mode as boolean
before of documents  iteration, if you use it in class
declare this variable as public,
        'Imports System.IO
        'Imports System.Linq
        Public Function GetDirectoryDocs(dirpath As String, subdirs As Boolean) As List(Of FileInfo)
            Dim dir As New DirectoryInfo(dirpath)
            If Not dir.Exists Then
                Throw New DirectoryNotFoundException()
                Return Nothing
            End If
            Dim opt As SearchOption = SearchOption.AllDirectories
            If subdirs = False Then opt = SearchOption.TopDirectoryOnly
            Return dir.GetFiles("*dwg", opt).AsEnumerable().OrderBy(Function(x) x.FullName).ToList()
        End Function
            ' set your folder path here:
            Dim drawings As List(Of FileInfo) = GetDirectoryDocs("C:\Test\BATM\Brad", False)
            Dim sb As New StringBuilder
            'save variable to check mode
            Dim checkreadonly = True
            Dim i As Integer = 0
            For Each dwgpath As FileInfo In drawings
                Dim mode As Boolean = IIf(i Mod 2 = 0, True, False)
                Dim doc As Document = dm.Open(dwgpath.FullName, mode)
                checkreadonly = doc.IsReadOnly
                sb.AppendLine(dwgpath.FullName + " : " + checkreadonly.ToString())
                ' increment to change open mode
                i += 1
            Next
            For Each doc As Document In dm
                If doc.Name <> curdoc.Name Then
                End If
            Next
            Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(sb.ToString())
        End Sub
~'J'~
Valued Contributor
Ertqwa
Message 5 of 7 (701 Views)
08-01-2012 10:40 AM in reply to: Hallex
Hi, ty for the response.
Still looks like you open a drawing first, and then check if it is read-only or not. I want to check before I open it if it is possible to open the drawing not read-only. Maybe there is no functionality in the CAD libraries to do this.
I''ve tried the following and it seemed to work.
if (File.Exists(strPath)) { objStreamWriter = new StreamWriter(strPath, true); if (objStreamWriter != null) { return false; } } return true;
dgorsman
Message 6 of 7 (697 Views)
08-01-2012 11:31 AM in reply to: Ertqwa
I'm not entirely certain there could be a method to do that - its a chicken-and-egg situation.  That determination isn't made until the drawing is actually opened.
You could take a more roundabout route, duplicating some of the checking that would be done e.g. checking for DWL/DWL2 files, checking on the file and/or folder rights levels for the active users, etc.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Contributor
Ertqwa
Message 7 of 7 (689 Views)
08-01-2012 01:35 PM in reply to: dgorsman
Ty for the response.
The OPEN command of AutoCAD has the same check. If you try to open a drawing not-readonly and you can't, it asks
for confirmation. Maybe it does the kind of checks that you suggest.
