.NET
osayed3202
Message 1 of 5 (449 Views)
DocumentManager.open() not open the file completely
449 Views, 4 Replies
01-07-2014 12:49 AM
Hi guys,
I am trying to open document according to the paths in the listview, the open() function when it opens the file the file doesnot open completely so it ignore the subsequent commands like ((acdMgr.MdiActiveDocument.SendStringToExecute("-purge all * n", false, false, true):smileywink:) , here is the code
            DocumentCollection acdMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
            string strFullPath;
            //string strTextFileName = SaveDialog.FileName;
            foreach (ListViewItem itemRow in this.lstView.Items)
                Transaction tm = acdMgr.MdiActiveDocument.Database.TransactionManager.StartTransaction();
                using (tm)
                    ListViewItem item = lstView.Items[itemRow.Index];
                    string lines = item.SubItems[0].Text;
                    string col = item.SubItems[1].Text;
                    strFullPath = col + "\\" + lines;
                    //acdMgr.Open(strFullPath, false);
                    acdMgr.Open(strFullPath,false);
                    acdMgr.MdiActiveDocument.SendStringToExecute("-purge all * n", false, false, true);
                    acdMgr.MdiActiveDocument.CloseAndSave(strFullPath);
                    tm.Commit();
                //tm.Commit();
 The image attached is for the cad screen after executing the open() function.
Best Regards
O.Sayed
CAD developer
It is not the open command which not open the drawing completely it is because the SendStringToExecute which is executed at the end of your command. You have to use SendCommand instead (assuming you have the CommandFlags.Session enabled).
You can also purge without sending a command.
If you use SendCommand or SendStringToExecute then you have to add " " or "\n" to command string, e.g. "_-purge _all * _n\n"
Valued Contributor
FRFR1426
Message 2 of 5 (412 Views)
Re : DocumentManager.open() not open the file completely
01-07-2014 12:02 PM in reply to: osayed3202
osayed3202
Message 3 of 5 (394 Views)
Re: DocumentManager.open() not open the file completely
01-07-2014 07:55 PM in reply to: osayed3202
thanks guys for your time and support
the sendcommand() works but i am struggling using it.
 private void btnPurge_Click(object sender, EventArgs e)
            string strFullPath;
                using (tm)
                    //Thread.Sleep(3000);
                    AcadApplication app = (AcadApplication) Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
                    app.ActiveDocument.SendCommand("(command " + (char)34 +
                                                    "-Purge" + (char)34 +
                                                    " " + (char)34 +
                                                    "all" + (char)34 +
                                                    " " + (char)34 +
                                                    "*" + (char)34 +
                                                    " " + (char)34 +
                                                    "n" + (char)34 +
                                                    " " + (char)34 +
                    // this is the output in the autocad command line : (command "-Purge" "all" "*" "n" ")
                    app.ActiveDocument.SendCommand("regen ");
                    //(command "-Purge" "all" "*" "n" ")
                    //acdMgr.MdiActiveDocument.SendStringToExecute("-purge all * n", false, false, true);
                    //acdMgr.MdiActiveDocument.CloseAndDiscard();
                    tm.Commit();
                //tm.Commit();
 the output in the autocad command line like this   (command "-Purge" "all" "*" "n" ") but did not work and stick in the command line and did not execute.
Best Regards
O.Sayed
CAD developer
Moderator
Alexander.Rivilis
Message 4 of 5 (369 Views)
01-08-2014 08:15 AM in reply to: osayed3202
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
osayed3202
Message 5 of 5 (352 Views)
01-08-2014 07:15 PM in reply to: Alexander.Rivilis
Thank you all guys,
really appreciate your time and support.
bye till another discussion :smileyhappy:
Best Regards
O.Sayed
CAD developer
