.NET
DocumentManager.MdiActiveDocument
2 REPLIES 2
1470 Views, 2 Replies
Can someone explain something to me?
I am trying to get the active document in AutoCAD using C#. To do this I am
using:
Document doc =
Autodesk.AutoCAD.ApplicationServices.DocumentManager.MdiActiveDocument;
To me this seems as if it should work as I am declaring the variable doc as
a Document and assigning it as the active document in AutoCAD. However when
I try to compile my code I get an error stating.
c:\Documents and Settings\TJRiley\My Documents\SharpDevelop
Projects\KSSetup\MainForm.cs(239,30): error CS0120: An object reference is
required for the nonstatic field, method, or property
'Autodesk.AutoCAD.ApplicationServices.DocumentManager.MdiActiveDocument'
Can someone please explain to me what this error message means?
Tim
2 REPLIES 2
cgay
Tim,
Hi, I think you need to get the document manager from the Application object, like this:
[code]
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
[/code]
Good Luck,
Clif
Doh...I can't believe I missed that.
Thank you very much.
Tim Riley
wrote in message news:4932513@discussion.autodesk.com...
Tim,
object, like this:
[code]
Document doc =
[/code]
Good Luck,
Clif
”Boost
