.NET
DocumentCollection and Database events issues
2 REPLIES 2
_gile
527 Views, 2 Replies
I want my application to display a message on opening a new document and on saving the active document.
So, in the Initialize method, I register a DocumentCollection.DocumentCreated and a Database.BeginSave one for all already opened documents.
The DocumentCreated callback method registers a Database.BeginSave for the new Document.Databse.
My questions are:
1- Do I need to unregister the DocumentCollection.DocumentCreated in the terminate method ?
2- Do I need to add a DocumentCollection.DocumentToBeDestroyed event with a callback to unregister the Database.BeginSave of this document ?
3- If so, do I need to unregister the DocumentCollection.DocumentToBeDestroyed in the Terminate method too ?
Here's an extract of what I wrote.
{code}
private DocumentCollection docMan = acadApp.DocumentManager;
public void Initialize()
docMan.DocumentCreated += new DocumentCollectionEventHandler(OnDocumentCreated);
docMan.DocumentToBeDestroyed += new DocumentCollectionEventHandler(OnDocumentToBeDestroyed);
foreach (Document doc in docMan)
doc.Database.BeginSave += new DatabaseIOEventHandler(OnSaveAlert);
AddDefaultContextMenu();
AddObjectContextMenu();
ShowMessage();
public void Terminate()
acadApp.RemoveDefaultContextMenuExtension(dcme);
RXClass rxc = Entity.GetClass(typeof(Entity));
acadApp.RemoveObjectContextMenuExtension(rxc, ocme);
try
docMan.DocumentCreated -= new DocumentCollectionEventHandler(OnDocumentCreated);
docMan.DocumentToBeDestroyed -= new DocumentCollectionEventHandler(OnDocumentToBeDestroyed);
catch (System.Exception ex)
System.Windows.Forms.MessageBox.Show("Terminte: " + ex.Message);
private void OnDocumentCreated(object sender, DocumentCollectionEventArgs e)
if (e.Document == null) return;
e.Document.Database.BeginSave += new DatabaseIOEventHandler(OnSaveAlert);
ShowMessage();
private void OnDocumentToBeDestroyed(object sender, DocumentCollectionEventArgs e)
Document doc = e.Document;
try
doc.Database.BeginSave -= new DatabaseIOEventHandler(OnSaveAlert);
System.Windows.Forms.MessageBox.Show("DocumentToBeDestroyed: " + ex.Message);
}{code}
Gilles Chanteau
GileCAD
GitHub
2 REPLIES 2
in reply to: _gile
Generally, you only need to unregister an event handler when the object
that's handling the event ceases to exist, rather than the object that fires
the event.
For Document, Editor, and Database events, you don't have to unregister
handlers of their events when the associated document is being destroyed,
because after that happens, all those objects will no longer exist and will
never fire events once they're gone.
That's not to suggest that you can't remove the handlers, you can, but if
you didn't it wouldn't matter.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
<_gile> wrote in message news:6281729@discussion.autodesk.com...
My questions are:
terminate method ?
{code}
ShowMessage();
try
ex.Message);
ShowMessage();
try
" + ex.Message);
}{code}
_gile
in reply to: _gile
Thanks Tony.
It makes sense.
Gilles Chanteau
GileCAD
GitHub
”Boost
