.NET
DocumentActivated got trigged more than once
2 REPLIES 2
wesbird
178 Views, 2 Replies
As my previous post: http://discussion.autodesk.com/thread.jspa?threadID=524751
I added a documentCollection.DocumentActivated in my palette function. The problem I have now is, it got trigged 4 time when I swich from doc A to doc B. It is no harm for my application now. Is this a bug? or should I handle it with special way?
Thank you,
Wes
AutoCAD 2006, VS 2003, Windows 2003 Server
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
in reply to: wesbird
Its a bug in your code. You are adding the
handler to the event source more than once.
That's the only way that can happen.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5416533@discussion.autodesk.com...
Thank you,
Wes
wesbird
Yes, Tony are right. The reason is there are 4 tabs in my Palette. But there is no way I can add DocumentActivated event handler at PaletteSet level. if correct, I have to live with it.
Thank you
Wes
”Boost
