.NET
Document.CloseAndSave: Attempted to read or write protected memory
0 REPLIES 0
Message 1 of 1
Ertqwa
801 Views, 0 Replies
Hello Forum,
I have code that throws the following error:
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
At Autodesk.AutoCAD.ApplicationServices.Document.CloseInternal()
At Autodesk.AutoCAD.ApplicationServices.Document.CloseAndSave()
It only happens with some drawings.
Why would "Document.CloseAndSave()" throw this error? How can I prevent this/check if the document is ok to be closed and saved?
using (Document docTarget = CADS.Application.DocumentManager.Open(strTargetDwgPath, false))
    try
        if (!docTarget.IsReadOnly)
            using (DocumentLock dlTarget = docTarget.LockDocument())
                using (Transaction transTarget = docTarget.Database.TransactionManager.StartTransaction())
                    btTarget = transTarget.GetObject(docTarget.Database.BlockTableId, OpenMode.ForRead) as BlockTable;
                    foreach (string strDwgPath in strSourceDwgPathList)
                        ++intIndex;
                        if (btTarget.Has(System.IO.Path.GetFileNameWithoutExtension(strDwgPath)))
                            using (Database dbInsert = new Database(false, true))
                                dbInsert.ReadDwgFile(strDwgPath, System.IO.FileShare.Read, true, "");
                                oidInsert = docTarget.Database.Insert(System.IO.Path.GetFileNameWithoutExtension(strDwgPath), dbInsert, true);
                            btrInsert = transTarget.GetObject(oidInsert, OpenMode.ForWrite) as BlockTableRecord;
                            if (btrInsert.IsDynamicBlock)
                                btrInsert.UpdateAnonymousBlocks();
                            ++intFound;
                        else
                            ++intNotFound;
                    btTarget = null;
                    transTarget.Commit();
            // Save changes.
            docTarget.CloseAndSave(strTargetDwgPath); // <<<< ERROR.
            enuResult = DialogResult.OK;
        else
            docTarget.CloseAndDiscard();
            mstrMessage = "Failed: file is readonly or in use.";
            enuResult = DialogResult.Cancel;
    catch (System.Exception Ex)
        MessageBox.Show(Ex.ToString(), "A");
        mstrMessage = "Error redefining blocks in multiple drawings: " + Ex.Message + " (" + System.Reflection.MethodBase.GetCurrentMethod().DeclaringType.Name + "." + System.Reflection.MethodBase.GetCurrentMethod().Name + ").";
        if (docTarget != null) { docTarget.CloseAndDiscard(); }
0 REPLIES 0
”Boost
