.NET
Hugh_Compton
Message 1 of 19 (1,117 Views)
Document CloseAndDiscard In 2013
1117 Views, 18 Replies
04-25-2012 04:27 AM
The Doc.CloseAndDiscard() method on documents returns message of ' not a member of 'Autodesk.AutoCAD.ApplicationServices.Document'.
How do we close a dwg file in AutoCAD 2013?
DocumentExtension.CloseAndDiscard
P.S.: Also read ObjectARX for AutoCAD 2013 Docs: Managed Class Reference -> Migration Guide->.NET Migration Guide
Not sure what your asking
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
<Assembly: CommandClass(GetType(AutoCAD_VB_plug_in1.MyCommands))>
Namespace AutoCAD_VB_plug_in1
Public Class MyCommands
<CommandMethod("MyCommand")> _
Public Sub MyCommand()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
doc.CloseAndDiscard()
End Sub
End Class
End Namespace
In the last example,
CloseAndDiscard does not show up in intellisense but it does build for me.
Moderator
Alexander.Rivilis
Message 2 of 19 (1,114 Views)
Re: Document CloseAndDiscard In 2013
04-25-2012 06:05 AM in reply to: Hugh_Compton
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Hugh_Compton
Message 3 of 19 (1,106 Views)
04-25-2012 06:41 AM in reply to: Hugh_Compton
Works great, thanks.
matus.brlit
Message 4 of 19 (792 Views)
03-01-2013 06:16 AM in reply to: Alexander.Rivilis
more clearly, it's DocumentExtension.CloseAndDiscard(doc)
just in case anyone would expect it to be an extension method, like i did
Valued Mentor
jeff
Message 5 of 19 (784 Views)
03-01-2013 10:06 AM in reply to: matus.brlit
It is a extension method
public static void CloseAndDiscard(this Document doc)
    CloseInternal(doc, true, null);
You can also find your answers @ TheSwamp
matus.brlit
Message 6 of 19 (757 Views)
03-03-2013 11:07 PM in reply to: jeff
I checked it and you're right, but I am using VB.net. And there it isn't an extension method.
Taken from MSDN:
Notice that the extension method definition is marked with the extension attribute <Extension()>. Marking the module in which the method is defined is optional, but each extension method must be marked. System.Runtime.CompilerServices must be imported in order to access the extension attribute.
Extension methods can be declared only within modules.
Valued Mentor
jeff
Message 7 of 19 (742 Views)
03-04-2013 05:49 AM in reply to: matus.brlit
With C# you import the namespace and VB you import the module, but it still is a extension method.
matus.brlit
Message 8 of 19 (711 Views)
03-07-2013 10:26 PM in reply to: jeff
I am importing
which is a class. I couldn't find the module I am supposed to import in VB. Do you know where I can find it?
Moderator
Alexander.Rivilis
Message 9 of 19 (706 Views)
03-08-2013 01:07 AM in reply to: matus.brlit
In AutoCAD 2013 class Autodesk.AutoCAD.ApplicationServices.DocumentExtension is in acmgd.dll
matus.brlit
Message 10 of 19 (701 Views)
03-08-2013 01:14 AM in reply to: Alexander.Rivilis
I know that, Alexander. I was asking about the module for VB.
