.NET
dockable palette
3 REPLIES 3
282 Views, 3 Replies
dockable palette
hi
which item ( user control or windows form )shall i take for create dockable form in auto cad 2008 and using vs 2005.
in my project i take windows form, its docking well but controls are not displayed.
can u give good suggestion.
venkatesh
3 REPLIES 3
cadMeUp
Check out the sample in the ObjectARX SDK at:
..\samples\dotNet\SimpleToolPalette
It gives a good working example.
hi this sample is for open the exist one. this is does not solved my problem.
so i created one usercontrol form and i link to palette it is working well, my was main problem is when i minimized or close the document
the dockable form all controls are not visible.
can u give one sample for create dockable form..
venkatesh
cadMeUp
Maybe you can provide your code to see where the problem is. You are using AutoCAD's toolpalletes? Is the form visible or does then entire form disappear?
”Boost
