.NET
Active Contributor
0 Kudos
Post 1 of 8
dock panel
234 Views, 7 Replies
11-10-2005 05:19 AM
Could anyone give me some example of dock panel by c#.net tools? I need see the codes. Thanks a lot.
*Bobby C. Jones
Post 2 of 8
Re: dock panel
11-11-2005 10:47 AM in reply to: connieleo
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Windows;
namespace AppPaneExample
public class ApplicationPanes
[CommandMethod("CreateAppPane")]
public static void AddApplicationPane()
Pane appPaneButton = new Pane();
appPaneButton .Enabled = true;
appPaneButton .Visible = true;
appPaneButton .Style = PaneStyles.Normal;
appPaneButton .Text = "Application Pane Button";
appPaneButton .ToolTipText = "This button is on the
application pane";
appPaneButton .MouseDown += new
StatusBarMouseDownEventHandler(OnMouseDown);
Autodesk.AutoCAD.ApplicationServices.Application.StatusBar.Panes.Add(appPane
Button);
private static void OnMouseDown(object sender,
StatusBarMouseDownEventArgs e)
Pane paneButton = (Pane) sender;
if (paneButton.Style == PaneStyles.PopOut)
paneButton.Style = PaneStyles.Normal;
Autodesk.AutoCAD.ApplicationServices.Application.StatusBar.Update();
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("The pane
is activated.");
else
paneButton.Style = PaneStyles.PopOut;
is de-activated.");
**WARNING** -- I ripped this out of some example code and modified it
slightly. It hasn't been tested.
Bobby C. Jones
http://www.acadx.com
wrote in message news:5009294@discussion.autodesk.com...
Active Contributor
0 Kudos
Post 3 of 8
Re: dock panel
11-13-2005 04:18 AM in reply to: connieleo
Thanks. I create the .cs file and .dll file. It can't appear the dock panel. Could you help me to see it?
*Bobby C. Jones
Post 4 of 8
Re: dock panel
11-14-2005 01:11 PM in reply to: connieleo
You must type "CreateAppPane" at the command line after loading the
assembly.
Bobby C. Jones
wrote in message news:5011745@discussion.autodesk.com...
Active Contributor
0 Kudos
Post 5 of 8
Re: dock panel
11-14-2005 06:52 PM in reply to: connieleo
Thank you for your answer. I type CreateAppPane in the command line. But nothing appears. What about in your computer? Thanks a lot.
*Jorge Jimenez
Post 6 of 8
Re: dock panel
11-14-2005 09:03 PM in reply to: connieleo
Are you looking at the status bar ? (at your screen's lower right corner)
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
wrote in message news:5013483@discussion.autodesk.com...
*Bobby C. Jones
Post 7 of 8
Re: dock panel
11-15-2005 06:09 AM in reply to: connieleo
It shows on mine.
Bobby C. Jones
Active Contributor
0 Kudos
Post 8 of 8
Re: dock panel
11-16-2005 02:23 AM in reply to: connieleo
Thanks a lot. Very appreciated.
Another question. Could anyone have the simple sample to show the dialog just like Design Center dialog. The dialog can exit in AutoCAD when you run other program in the command. Thanks again
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
