.NET
doc.TransactionManager or db.TransactionManager
1 REPLY 1
Dale.Bartlett
971 Views, 1 Reply
Dumb question: What is the difference? When to use one or the other? I've made the usual investigation and found these very good articles:
http://spiderinnet1.typepad.com/blog/2012/04/database-transactionmanager-and-document-transactionman...
http://spiderinnet1.typepad.com/blog/2012/05/document-transactionmanager-is-nowhere-for-external-dat...
Can anyone add some additional insight? It appears that db.TransactionManager will serve in all situations. Thanks, Dale
______________
Yes, I'm Satoshi.
1 REPLY 1
jeff
in reply to: Dale.Bartlett
Loooking at it quickly in reflector it inherits from TransactionManager and looks like it just adds the functionality to flush graphics
[Wrapper("AcTransactionManager")]
public sealed class TransactionManager : TransactionManager
    // Methods
    internal TransactionManager(IntPtr unmanagedObject, [MarshalAs(UnmanagedType.U1)] bool bAutoDelete);
    protected sealed override void DeleteUnmanagedObject();
    public void EnableGraphicsFlush([MarshalAs(UnmanagedType.U1)] bool doEnable);
    public void FlushGraphics();
    internal unsafe AcTransactionManager* GetImpObj();
    public sealed override Transaction StartTransaction();
    // Properties
    public override Transaction TopTransaction { get; }
 It uses a AppTransaction that inherits from Transaction looks it just overrides Commit() and uses base functionality then flushes the graphics.
internal sealed class AppTransaction : Transaction
    // Fields
    private TransactionManager m_mgr;
    // Methods
    protected internal AppTransaction(IntPtr unmanagedPointer, [MarshalAs(UnmanagedType.U1)] bool autoDelete, TransactionManager mgr) : base(unmanagedPointer, autoDelete)
        this.m_mgr = mgr;
    public sealed override void Commit()
        base.Commit();
        ((TransactionManager) this.TransactionManager).FlushGraphics();
    // Properties
    public override TransactionManager TransactionManager
        get
            return this.m_mgr;
So looks like if want to call FlushGraphics for each commit then use the Document TransactionManager.
Now that I say that seems like I just saw Tony mention to use the Documents Transmamnger when it came to regenerating graphics or something similar.
You can also find your answers @ TheSwamp
”Boost
