.NET
DllImport for acedGetEnv....
9 REPLIES 9
Message 1 of 10
StormyC
2999 Views, 9 Replies
Got what I think is an odd situation.  Im trying to access the support paths using the dll import that can be found in a number of sites.  Problem is, the entry point doesnt seem to exist - im sure it worked before.. any help would be appreciated.
AutoCAD2014, Win7 64, VSExpress2010, C#
9 REPLIES 9
Message 2 of 10
Alfred.NESWADBA
in reply to: StormyC
acedGetEnv is placed in ACCORE.DLL and not in ACAD.EXE (I guess since 2013).
BTW: why don't you use the more direct option to get sysvar's:
   Public Shared Function GetSystemVariable(name As String) As Object
      Member von Autodesk.AutoCAD.ApplicationServices.Core.Application
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
StormyC
in reply to: Alfred.NESWADBA
Thanks for the reply, but, I dont think the support file search path is a system variable that can be edited that way.
Message 4 of 10
Alfred.NESWADBA
for editing:
   Public Shared Sub SetSystemVariable(name As String, value As Object)
- alfred -
Alfred NESWADBA
Message 5 of 10
StormyC
The system variable is readonly....
Message 6 of 10
Alfred.NESWADBA
Which sysvar?
And back to start:
Have you seen my first sentence in my first post?
At least:
Does >>>that thread<<< abotu adding a path to the list of support paths help?
- alfred -
Alfred NESWADBA
Message 7 of 10
_gile
As Alfred said, since AutoCAD 2013, the acad.exe file have been splited into acad.exe and accore.dll.
Try replacing acad.exe with accore.dll in the DllImport arguments.
Anyway, to get and/or set support paths, you can use COM to access to AutoCAD preferences.
This needs to reference the COM librairies or use the Dynamic type. The inconvenients of the first route are the advantages of the second one and vice versa.
Referencing COM libraries means using static typing with type checking at compile time which is a great help during edition time (intellisense), but COM librairies are verion and processor architecture dependant which may be an inconvenient.
Using COM libraries
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Runtime;
namespace AcadPreferencesStaticTyping
    public class CommandMethods
        [CommandMethod("Test")]
        public void Test()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            AcadPreferences prefs = (AcadPreferences)Application.Preferences;
            string[] supportPaths = prefs.Files.SupportPath.Split(';');
            foreach (string str in supportPaths)
                ed.WriteMessage("\n{0}", str);
Using Dynamic type
namespace AcadPreferencesDynamicTyping
        public void Test()
            dynamic prefs = Application.Preferences;
As the codes are very similar, it's quite easy to reference the COM libraries while writing an debugging and, when all works as expected, remove these references and replace the COM types with the 'dynamic' keyword.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 10
StormyC
Which Sysvar:  ACADPREFIX
Yes, saw your first sentance but for some reason i didnt think it was the same thing as importing from the .exe
Forgive me, Ive just tried it by importing from ACCORE.DLL and that works, for reading & writing.
Your other link is to use the interop library, which I wanted to avoid.
Many Many thanks for your help!!
How did you find that acedGetEnv had moved?
Again Thanks!
Message 9 of 10
StormyC
in reply to: _gile
Gilles, many thanks for that reply - I had read about dynamic types but forgotten about them.
I may just rewrite it to use those.
Thanks both!
Message 10 of 10
Alfred.NESWADBA
>> Forgive me,
You are welcome, no need to appologize, the most important thing is you got it solved and you can continue to work 😉
For Invokes and similar things I use Dependency Walker >>>click<<<.
- alfred -
Alfred NESWADBA
”Boost
