.NET
191 Views, 2 Replies
DLL
When I try to use regsvr32 to register a DLL i
created i get the message that the entry point was not found.
Any suggestions?
Dale
size=2>
2 REPLIES 2
NathTay
If it is a .NET dll how are you using it. You may not need to register it at all or use Regasm.exe.
Regards - Nathan
You only register it if its set for COM InterOp
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
”Boost
