.NET
.NET
Valued Contributor
dynamicscope
Message 1 of 2 (697 Views)
Divide(Measure) a Polyline with a certain interval
697 Views, 1 Replies
07-16-2012 10:43 PM
Is it possible to divide a polyline into multiple segments with a certain interval?
I am looking for something similar to "Measure" command.
But I want to do this programmatically.
SendStringToExcute("measure ");
quite does not help.
I need the point objects created by "measure' commnad in order to draw a new polyine with them.
Of course, "SendStringToExcute" does not return such object collection.
Does anyone know how to solve this problem?
If you could provide me with C# (or .NET ObjectARX 2010) code snippet, it would be appreciated.
Thank you very much.
Jake
Hallex
Message 2 of 2 (694 Views)
Re: Divide(Measure) a Polyline with a certain interval
07-16-2012 11:37 PM in reply to: dynamicscope
Try this code
        //      FH
        [CommandMethod("measp")]
        public static void testMeasure()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            object osm = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("osmode");
            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("osmode", 512);
            double fuzz = (double)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dimtxt");
            if (fuzz == 0) fuzz = 0.01;// change fuzz to your needs (say 0.1 or so)
            PromptPointOptions ppo = new PromptPointOptions("\nPick a point near to the start of curve: ");
            PromptPointResult ppr = default(PromptPointResult);
            ppr = ed.GetPoint(ppo);
            if (ppr.Status != PromptStatus.OK)
                ed.WriteMessage("\nwrong point specification!");
                return;
            Point3d p = ppr.Value;
            Vector3d vd = new Vector3d(fuzz, fuzz, 0);
            Point3d pMin = p - vd;
            Point3d pMax = p + vd;
            TypedValue[] tvs = new TypedValue[] { new TypedValue(0, "lwpolyline") };
            Point3dCollection points = new Point3dCollection();
            points.Add(pMin);
            points.Add(pMax);
            SelectionFilter sf = new SelectionFilter(tvs);
            PromptSelectionResult sres = ed.SelectFence(points, sf);
            if (sres.Status != PromptStatus.OK)
                ed.WriteMessage("\nWrong selection!");
                return;
            if (sres.Value.Count == 0)
                ed.WriteMessage("\nNothing selected!");
                return;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                try
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    ObjectId eid = sres.Value.GetObjectIds()[0];
                    Entity ent = tr.GetObject(eid, OpenMode.ForRead) as Entity;
                    // cast entity as Polyline
                    Polyline pline = ent as Polyline;
                    if (pline != null)
                        ed.WriteMessage("\n{0},{1}", pline.StartPoint.X, pline.StartPoint.Y);
                    Point3d px = pline.GetClosestPointTo(pMin, false);
                    double leng = pline.Length;
                    bool endclick = false;
                    if ((pline.GetDistAtPoint(px) > leng / 2))
                        endclick = true;
                    double theight = db.Textsize;
                    if (theight == 0) theight = db.Dimtxt;
                    double step = 50.0;// <---  change the step to your needs*************************************************
                    int num = (int)(leng / step);
                    double ang;
                    int n = 1;
                    Plane plan = pline.GetPlane();
                    Line ln = null;
                    DBText txt = null;
                    Vector3d vect = new Vector3d();
                    Vector3d vec = new Vector3d();
                    Point3d ptxt = new Point3d();
                    Point3d ppt = new Point3d();
                    Point3d pptx = new Point3d();
                    if (!endclick)
                        for (n = 0; n < num + 1; n++)
                            ptxt = pline.GetPointAtDist(step * n);
                            vec = pline.GetFirstDerivative(ptxt).GetPerpendicularVector();
                            ppt = (ptxt + vec * theight * 8).TransformBy(ucs);
                            pptx = (ptxt + vec * theight * 5).TransformBy(ucs);
                            ln = new Line(ptxt, ppt);
                            btr.AppendEntity(ln);
                            tr.AddNewlyCreatedDBObject(ln, true);
                            vect = ln.GetFirstDerivative(ppt).GetPerpendicularVector();
                            txt = new DBText();
                            txt.Position = pptx;
                            txt.TextString = string.Format("{0:f2}", n * step);// <---  change precision to your needs*************************************************
                            txt.HorizontalMode = TextHorizontalMode.TextCenter;
                            txt.VerticalMode = TextVerticalMode.TextBottom;
                            txt.AlignmentPoint = pptx;
                            ang = ln.Angle + Math.PI;
                            if ((ang > Math.PI / 2) || (ang < Math.PI * 1.5))
                                ang = ang + Math.PI;
                            txt.Rotation = ang;
                            btr.AppendEntity(txt);
                            tr.AddNewlyCreatedDBObject(txt, true);
                        ptxt = pline.EndPoint;
                        txt = new DBText();
                        txt.TextString = string.Format("{0:f2}", leng);// <---  change precision to your needs*************************************************
                        txt.Rotation = ang;
                    else
                        for (n = num; n >= 0; n--)
                            txt = new DBText();
                            txt.Rotation = ang;
                        txt = new DBText();
                        txt.Rotation = ang;
                    db.TransactionManager.QueueForGraphicsFlush();
                    tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    MessageBox.Show(string.Format("Error:\n{0}\nTrace:\n{1}", ex.Message, ex.StackTrace));
                finally
                    Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("osmode", osm);
~'J'~
