You do not distribute them (nor you have right to do so, I think). They are
part of AutoCAD installation. That is, if your user has the proper version
of Acad installed, the files should be there; if the user does not have Acd
installed, your app simply cannot run, whether you distribute them or not.
If the user have different version of Acad, then it is another story (still,
you do not distribute the said files) that your app may or may not run,
depending how do you deal with multiple version issue.
"Kent Sauder" wrote in message
news:5551183@discussion.autodesk.com...
I'm creating a VB .net application that uses the AutoCAD type library and
the AutoCAD/ObjectDBX Common Type library. Can these two DLLs be
distributed along with the application. This is not an application that we
are selling but is to allow our customers to import our drawings into their
copy of AutoCAD.
If they can't be redistributed along with the application, how can I
reference the customer's copy of these DLLs regardless of the version of
AutoCAD they are using. It appears that the reference in VB refers to the
exact version of AutoCAD I have installed.
